Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    May 2017
    Nagpa vehicle inspection tests kami. Sabi sa report the stabilizer links are worn out while the Suspension Arm Assembly are lower/worn out too. Hindi ba pwede after 5 years ko na lang iparepair ito? Sobrang mahal kasi. Halos aabutin ng 5,400 for Stabilizer and 21,200 pesos for Suspension Arm Assembly.
    Kakaayos lang ng Drive Belt at ATF Transmission Fluid replacement. Medyo ayaw ko muna gumastos e...
    Any thoughts/opinions?
    errr...
    what car, po?
    off-road use ba 'yan, at mabilis ma-upod?
    and why the magic number of 5 years?
    the stabilizers are to make the car less unwieldy on the roads, what with turns and such.
    the suspension arms...
    are important in steering the car,
    and prevent your car from collapsing onto the road surface.
    biglang bumibigay o kumakalas ang suspension arm, with little or no warning.
    if i had to choose to fix only one, i'd choose the suspension arm first.
    but i really would want to fix both of them already.
    ...casa estimate ba yan?
    bring it to non-casa mekaniko. banawe.
    i am sure, they will be considerably cheaper (50% ?) and much faster.
    tongue-in-cheek,
    "if you're not gonna use the car, it's ok not to have these fixed."
    Nov 2019
    Depending on the car but stabilizer link is just 400 - 800 Php lang po (or if you found a good brand, it should only cost 1k-2k range).
    Then mga 400-600 labor.
    If that's out of warranty, much better if sa labas mo nalang ipapagawa.
    Apr 2012
    presyong casa yata yan[emoji85] and why wait for 5 years? anong car? warranty?
    try other shops specializing in underchassis repair. no idea sa price but hindi naman ganyan presyuhan. need na i fix yan dahil connected sa steering. iirc, one of may ELF truck dati ay nagkaisyu sa stabilizer, mahigpit mapihit pakanan, sa starman ko pinaayos, naging ok naman.
    Jul 2013
    normally naman bushings lang nyan ang kailangan palitan...
    not unless sobrang pudpod na yung bushings and sinira nya na yung mount.
    "in the casa, they replace entire assemblies."
    walang tinge-tinge sa casa.
    para raw sigurado't walang back-job.
    Apr 2012
    agree with you bro. yung stabilizer, kung hindi pa naman pudpod yung thread sa dulo, no need palitan. palit bushings at grinagrasahan lang yan
    Agree with the guys. Both are safety issues. Kung nagtitipid, you can get quality replacement parts instead of original parts. If the control arms are still ok and only the bushings are damaged, you can have new bushings pressed.
    The Japan made replacement brands are ok. And cost only a fraction of original parts.
    Another thing with the arms. If you don't fix them soon they will cause your tires to wear unevenly. Mabilis yan mauubos. Gastos na naman yun.
    Jul 2013
    Based on my personal experience... (Except for the 88-91 Lancer)
    Sirang bushing/stabilizer etc will result to the following:
    Kalampag
    Affect vehicle stability (cornering/acceleration/braking)
    Affect alignment and camber
    (Yung Lancer ko bigla na lang tumirik )
    If wala kang nararamdaman/nakikitang/naririnig na issue... Baka pwede pa maghintay ng 5 years.
    Pero 5 years later... May pagagawa ka nanaman ulit. Paluma nang paluma yung car, palaki mg palaki ang gastos.
    bro ano sasakyan mo? these two parts are not that expensive. over priced yan quote sayo. original stablinks more or less 2000, Lower arm assembly (balljoint and two bushings) more or less 10,000.
    edit: mukhang pairs ata yun quote lol
    May 2017
    errr...
    what car, po?
    tongue-in-cheek,
    Kia Sportage 2014 po, nasa 110,000 mileage na. Ang Rapide ang nagbigay ng suggestion and price. But when I am driving it and making turns mukhang ok naman eh...
    Ah kaya naman pala rapide ka nagpa check. Maayos pa yan hinde pa sira
    May 2017
    oo pares (2) yung nakasulat, nakakapagduda ba? Dapat isa lang muna ang nasisira di ba?
    (2) stabilizer links = 2,700 x 2 = 5,400
    (2) Suspension Arm assembly = 10,600 x 2 = 21,200pesos
    May 2017
    Well Kia Sportage bought last 2014 as bnew, bakit parang ang bilis naman yatang masira, ganito ba ang SUV quality?
    Well nakasulat "Worn-out" na daw ang stabilizer link and Suspension Arm assembly, pero ok naman siya when I'm driving and making a turn...
    What is it about Rapide ba?
    basta underchassis kung walang obvious na sira or wala ka naman nafefeel na lagutok kalampag eh wag pagawa.
    Jan madami nagigign "inventor" na talyer.
    Wala kasi evidensya. Pwede lang sabihin na sira ito sira yan.
    Try mo kay exalta banawe n.roxas or kay goodyear servitek quezon avenue bago mag jollibee d.tuazon. Sa experience ko yan matitino magcheckup.
    Basta find 5 talyer and check mo if same diagnosis.
    Nov 2017
    malaki pinatong nila sa stabilizer links 950 rear 1100 front(set na ng dalawa left and right) lang yan sa shopee
    https://shopee.ph/Hyundai-Tucson-Kia...gaAnanEALw_wcB
    https://shopee.ph/Front-Stabilizer-L...waAgDnEALw_wcB
    May 2017
    Well "Worn-out" does not mean SIRA di ba?
    May 2017
    By the way pinacheck ko ang Wheel Alignment sa another Tire store, sabi ng mechanic ok naman at naka-Wheel Alignment pa daw ang 2 front wheels. So no need to pay for a Wheel Alignment, binigyan ko na lang ng tip.
    Hindi ba kapag sira ang stabilizer links and suspension arm assembly , hindi pwedeng mag alignment ang 2 front wheels?
    May 2017
    Quote Originally Posted by LOLZ View Post
    laki nga noh...
    May 2017
    bakit kaya sa akin, kapag kumakanan, very easy and obedient naman ang sasakyan?
Ok lang ba hindi muna ipagawa ang Stabilizer links and Suspension Arm Assembly?
