Results 1 to 20 of 25
    May 2012
    Hi!
    Has anyone tried this product?
    ## TTC Polyurethane Cushion ##
    I would like to know if this has improved the ride of your vehicle(s). It is kinda expensive, but I've not read any reviews, so I am quite curious... perhaps it will be good for my Suzuki Jimny...
    Thanks.
    Jaime
    sir, parang katulad din yan ng o-sulee spring cushion, sa akin lang ha, not worth it
    Quote Originally Posted by seymorebutts View Post
    na try mo na sir eto or o-sulee? am planning to install o-sulee sa rear coil spring ng santa fe ko para di mag bottom out if puno ng passengers (7). kasi pag 7 passengers na, bottom out na rear end ko ang mas mataas na front end niya. will this problem be solved by installing this? thanks
    May 2012
    Saan po nabibili yung O-sulee?
    Are there any other brands available out on the market? Preferably cheaper?
    Any other inputs, experience?
    meron pa ibang brand na taiwan din. clear polyurethane sya. i forgot the brand. o-sulee madami sa banawe yellow orange poly sya
    Aug 2012
    at available din ang o-sulee spring cushion sa blade asia / true value at handyman
    Nov 2007
    Up
    Posted via Tsikot Mobile App
    Aug 2011
    Sir advisable ba lagyan lahat or sa front lang? TIA
    Jul 2011
    I have a set of o-sulee spring cushion sa rear suspension ko,
    sulit sya for me, greatly lessens the chance of my shocks
    bottoming out and hindi tumitingala masyado yung kotse pag mabigat ang load.
    sa harap i didn't bother lagyan.
    Aug 2011
    Quote Originally Posted by 7138 View Post
    Thank you sir for the inputs. Wala ba nagbago sa ride height? How about sir ung body roll? TIA
    Jul 2011
    Quote Originally Posted by Tj_abs View Post
    wala nagbago sa ride height.
    about sa body roll, hindi ko alam, baka may nagbago,
    hindi ko lang napapansin.
    Aug 2011
    Thanks
    Nov 2007
    Nice! May sale osulee sa transport show e
    di ko makuha ang pint ng cushions na ito, kung nag-bo-bottom out ang shocks, ibig sabihin palitin na. ganun din sa springs, ibig sabihin nabanat na at kailangan bumili ng bago or change to uprated ones.
    Tinapon ko na bro, hehe
    I don't really believe in these. I get that the idea is to get an effectively softer spring by using fewer coils for the amount of travel given in a bump, but IMO a better solution would be to fit a proper progressive spring or helper spring setup from the start.
    2015 fortuner. it has lessened the jittery feeling but just a bit. noticeable but only just. I think ang tanong lang dito with your suggestion is willing ba yun owner na gumastos ng suspension parts maski hindi naman sira yun papalitan for added comfort. So cost proposition ito. magkano ba spring cushion ngayon versus a spring and damper change? no wrong or right answer. in our case nun bumili kami cushion. i can or have to live with the ride. Ayoko na gumastos but I understand those who do. in fact my mom has a 2016 o 17 ata na fortuner my dad has a 2019 hilux. our 2015 fortuner has the worst ride of the three. yes imo even the new hilux rides better. our old 2012 Montero rides far better than all of them.
TTC Polyurethane Cushions for Coil Springs... any good?
