Results 1 to 20 of 42
    Apr 2012
    presyong casa yata yan[emoji85] and why wait for 5 years? anong car? warranty?
    try other shops specializing in underchassis repair. no idea sa price but hindi naman ganyan presyuhan. need na i fix yan dahil connected sa steering. iirc, one of may ELF truck dati ay nagkaisyu sa stabilizer, mahigpit mapihit pakanan, sa starman ko pinaayos, naging ok naman.
    Jul 2013
    normally naman bushings lang nyan ang kailangan palitan...
    not unless sobrang pudpod na yung bushings and sinira nya na yung mount.
    "in the casa, they replace entire assemblies."
    walang tinge-tinge sa casa.
    para raw sigurado't walang back-job.
    Apr 2012
    agree with you bro. yung stabilizer, kung hindi pa naman pudpod yung thread sa dulo, no need palitan. palit bushings at grinagrasahan lang yan
    Agree with the guys. Both are safety issues. Kung nagtitipid, you can get quality replacement parts instead of original parts. If the control arms are still ok and only the bushings are damaged, you can have new bushings pressed.
    The Japan made replacement brands are ok. And cost only a fraction of original parts.
    Another thing with the arms. If you don't fix them soon they will cause your tires to wear unevenly. Mabilis yan mauubos. Gastos na naman yun.
    Jul 2013
    Based on my personal experience... (Except for the 88-91 Lancer)
    Sirang bushing/stabilizer etc will result to the following:
    Kalampag
    Affect vehicle stability (cornering/acceleration/braking)
    Affect alignment and camber
    (Yung Lancer ko bigla na lang tumirik )
    If wala kang nararamdaman/nakikitang/naririnig na issue... Baka pwede pa maghintay ng 5 years.
    Pero 5 years later... May pagagawa ka nanaman ulit. Paluma nang paluma yung car, palaki mg palaki ang gastos.
    bro ano sasakyan mo? these two parts are not that expensive. over priced yan quote sayo. original stablinks more or less 2000, Lower arm assembly (balljoint and two bushings) more or less 10,000.
    edit: mukhang pairs ata yun quote lol
    May 2017
    oo pares (2) yung nakasulat, nakakapagduda ba? Dapat isa lang muna ang nasisira di ba?
    (2) stabilizer links = 2,700 x 2 = 5,400
    (2) Suspension Arm assembly = 10,600 x 2 = 21,200pesos
    basta underchassis kung walang obvious na sira or wala ka naman nafefeel na lagutok kalampag eh wag pagawa.
    Jan madami nagigign "inventor" na talyer.
    Wala kasi evidensya. Pwede lang sabihin na sira ito sira yan.
    Try mo kay exalta banawe n.roxas or kay goodyear servitek quezon avenue bago mag jollibee d.tuazon. Sa experience ko yan matitino magcheckup.
    Basta find 5 talyer and check mo if same diagnosis.
    May 2017
    Well "Worn-out" does not mean SIRA di ba?
    Nov 2017
    malaki pinatong nila sa stabilizer links 950 rear 1100 front(set na ng dalawa left and right) lang yan sa shopee
    https://shopee.ph/Hyundai-Tucson-Kia...gaAnanEALw_wcB
    https://shopee.ph/Front-Stabilizer-L...waAgDnEALw_wcB
    May 2017
    By the way pinacheck ko ang Wheel Alignment sa another Tire store, sabi ng mechanic ok naman at naka-Wheel Alignment pa daw ang 2 front wheels. So no need to pay for a Wheel Alignment, binigyan ko na lang ng tip.
    Hindi ba kapag sira ang stabilizer links and suspension arm assembly , hindi pwedeng mag alignment ang 2 front wheels?
    May 2017
    Quote Originally Posted by LOLZ View Post
    laki nga noh...
    May 2017
    bakit kaya sa akin, kapag kumakanan, very easy and obedient naman ang sasakyan?
    Nov 2017
    kung okay naman lumiko baka naman nde pa talaga worn out ung parts na sinasabi nila?
    May 2017
    baka iba ang definition nila ng "worn-out": it is overused but can still be used...
    Nov 2019
    Kung gusto talaga makasiguro, pwd mo ata pa check either DIY or sa Gas station.
    Pa lift mo lang, tapos i try mo sway yung stabilizer link.
    Dapat matigas o hindi madaling gumalaw yung stabilizer link if ok pa siya.
    If sa rear naman, may maririnig kang kalampag dapat if worn out na.
    Same din ang process if gusto mo talagang i check if worn out siya or not.
    May 2017
    Quote Originally Posted by carxynogen View Post
    thanks for the tip
    Apr 2012
    better still, ipa-check mo sa ibang underchassy specialist and get their diagnosis and repair quotation. do not tell the findings/price quote of rapide.
    May 2017
    Salamat Bossing, pero nabasa ko na sa Tsikot yung negative feedback about Rapide, pwede ka pala ma-ban sa Tsikot kapag pumupunta ka sa Rapide... lol
    RAPIDE FeedBack Thread [merged] (horror stories & others)
Ok lang ba hindi muna ipagawa ang Stabilizer links and Suspension Arm Assembly?
