Results 1 to 10 of 32
November 24th, 2015 06:38 PM #1
Mga sir bakit kaya lagi nag babago alignment nung grace ko nag paalign ako sa Yokohama pro mga 2months na nag bago uli at na pudpod labas ng gulong bali 2 gulong sa harap ang ganun pinalitan na rin yung bolt dun sa lower suspension arm tsaka bushing pro ganun pa din
- 52,836
November 24th, 2015 06:51 PM #2i can only suspect, that your ball joints and, perhaps the other components as well, are already worn... too much play siguro.. replace and align is my recommendation.
November 25th, 2015 07:17 AM #3
If you have the alignment reading printout it is the best info to make diagnosis even without looking at the car
- Mar 2010
- 2,259
November 25th, 2015 07:46 AM #4
November 25th, 2015 08:13 AM #5
November 25th, 2015 10:42 AM #6
The computerized alignment maybe:
1-miscalibrated
2-improperly used
3-used by an untrained/incompetent mechanic
Between the optical laser aligner and the computerized one, I still trust the optical laser over the fancy computerized system
- Jan 2014
- 655
November 25th, 2015 09:45 PM #7Dapat ba 0 lagi camber? Last alignment ko kasi sinet sa 0.2 sabi niya ganun daw setting talaga. Normal driving condition ko nga lang pala gamit lagi
November 25th, 2015 09:52 PM #8
- Aug 2013
- 475
November 26th, 2015 09:53 AM #9kung may makikita kayong toe and camber alignment tool na "bula", parehas sa mga level na gamit sa construction, mas maganda.
sa south, meron nito, si JPWheels. (merong sila facebook para sa directions).
sakin naman, hindi ko pinapa set sa zero o positive camber. lagi akong naka negative. mga -0.5 to -0.8 degrees.
November 27th, 2015 05:53 AM #10
On the old Innova, the external antenna is placed on the rear-left corner of the roof. The cable...
