Page 1 of 3 123 LastLast
Results 1 to 20 of 50
    My 2004 Mazda 3 has developed a rattle that can be heard when the rear left tire passes through a road imperfection. It sounds like there's something in the trunk that's bouncing around.
    Of course, first thing I did was empty my trunk - rattle was still there. Then, I removed the jack, spare tire, and all tools, rattle was still there. I checked all clips, rattle was still there.
    Next step was to have the suspension checked. I changed my shocks, but the rattle was still there. I even changed my stab links, but rattle remained (waste of money oh well). I also tried a new shock mount, new shock boot, and new lateral links, but the problem still persisted.
    I already had 2 shops look at the suspension and both said that it was fine. So now, I'm quite stuck as I dunno what to check next.
    One shop suggested that there might be some screws stuck in between the metal panels of the car that shakes around when passing through road ruts. Oddly enough, we can't reproduce the problem by bouncing the rear when it's stopped. You only hear it when the car is moving and the left rear tire passes encounters potholes.
    If anyone has any idea on what the problem could be, or could suggest a shop that specializes on issues like this, I'd gladly appreciate the help. [emoji4]
    Jun 2005
    My cousin had a similar problem but for a 2008 city. Car stayed weeks sa casa and also sa honda spa. Never found the problem.
    Then dinala nya sa cruven. May naipit pala maliit na bato somwhere sa suspension arms. Tinanggal lang yung bato. Okay na.
    Have you checked the exhaust? Could be a worn out exhaust mount.
    Quote Originally Posted by sirkosero View Post
    Thanks for the tip. How's the pricing of Cruven? Might bring it there for diagnosis.
    Quote Originally Posted by Monty View Post
    Had it checked already, the rubber mounts are still in good condition.
    Jan 2009
    Other things to look at is the trunk mechanism (hinge/latch), tailights, bumper mounts/clips... technically, everything that isn't welded on.
    On older cars, body flexing or body panels moving against its mount because of flexing, can sometimes cause creaks and 'tick' noises when certain corners of the vehicle is subjected to stress.
    This may sound funny and draconian but have you tried locking yourself or an assistant inside the trunk and have you/someone drive the car (carefully) over a pothole? That will help localize the source of the rattle. But do this in a controlled environment (parking lot, driveway, or a seldom-used street).
    Funny, but we actually tried that out of desperation. To be a bit humane though, I opened the 60/40 split rear seats to get some air into the trunk. [emoji16]
    The guy isolated the noise to the left rear quarter panel. We tried checking all the suspension bits and they checked out fine.
    Jun 2005
    My cousin just gave a tip to the mehanic. Check up lang daw ginawa sabi ng mechanic
    Jan 2009
    What did the noise sound like (tick, bang, tok, etc.)? How do you reporduce it or what kinds of bumps/potholes does it respond to and at what speed?
    Is it a one-time tick or does it dribble?
    Describe it as detailed as possible.
    It dribbles, and I'm able to reproduce the sound when I pass through small road imperfections. I usually run over cat-eyes in the middle of the road to make the sound come out.
    It sound a bit like putting a marble in a jar and shaking it. The sound comes out at any speed.
    Jan 2009
    You didn't mention about checking the brakes. It could be the brake pads rattling about (it could happen if it somehow didn't self-adjust or the brake pads have become worn out). Does the noise stop, continue or change in pitch while the brakes are applied?
    If it's behind the quarter panel, I'd go one more step and remove the interior lining on that side. With a suitable mirror and a good flashlight, you should be able to visually see behind the double-wall. Or do it while driving the car one more time with your guy in the trunk.
    try the rubber bushing. it might be worn, and the metal strut rubs onto the side of the metal hole.
    I'll try riding the brakes while going through bumps to see if it eliminates the rattle.
    Removing the interior lining is my next plan which I'll make Cruven do when I have time. Mahirap pag nag-destroy it yourself ako.
    The Mazda 3 doesn't have struts in the rear, but rather an independent multi-link setup where the shock absorber is separate from the coils.
    Nonetheless, I already tried replacing the rubber boot (equivalent to the rubber at the bottom of a strut up front) that covers the end of the shock. No improvement on the rattle. 😕
    Mar 2011
    Disc brake ba rear nyan.
    In my sentra, although sa front, rattling sound pag nag loose na yung pin ng caliper?
    I tried riding the brakes while going through potholes - no difference compared to no brakes. May kalampag pa rin. [emoji20]
    i read the whole thread but i still couldnt visualize where exactly is the rattling sound youre talking about. so id go with stupid answer... seatbelt hitting something... :D
    i do not have any mazda, pero i noticed sa vios ko is the rattling sound came from the headlights. tumatama sa bakal ng body.
    so it might be good to check ung mounting ng lights (break, trunk and other) baka maluwag or worn out na ung gasket. silicone sealant might help.
    Oct 2013
    Quote Originally Posted by RomeoAlpha View Post
    from my idol
    i googled for a picture of the mazda3 rear suspension..
    ang daming turnilyo!!
    ... checked them all, i suppose..?
    Quote Originally Posted by screws View Post
    Rear left quarter panel. Taas ng wheel well ng rear left wheel, sa may trunk.
    May silicone sealant na yung rear tail lamp ko, pinalagay ko nung nagkaleak yung kanan and pinasok ng water yung tail lamp assembly. Now, both tail lamps are sealed and hindi na pinapasok ng water.
    I've had each bolt and nut re-torqued countless times, ganun pa rin.
    The rattle isn't particularly noisy - you'll only notice it if you drive the car everyday with the radio off. Nakaka-OC lang talaga since noone can seem to figure out where it's coming from. It just sounds like things rattling in the trunk, even if my trunk is empty.
Unknown Kalampag (Not Suspension-related)
