Results 51 to 54 of 54
January 19th, 2020 11:31 AM #51
Did you change the ball joint on each arm? That's a part no one wants to go back in & replace later. If so, what brand? Mevotech? Febest? 555? Where sourced?
The bud's CX5 KE was silenced back to bnew w/ all genuine mounts & arms. The old parts kept & will be rehabbed w/ PU bushes for the next expected swap, 7years away....or hopefully much later.[emoji4]
- Sep 2019
- 107
January 19th, 2020 03:50 PM #52Hindi ko pa pinapalitan yun ball joint sir. Nun pinacheck ko ball joint ok pa naman daw. Kahit tumagal lang ng atleast few years sir if may masira ulit na parts sa lower control arm(ball joints or bushing) nasulit ko na din. Pero when the time comes I will replace the entire assembly na with Mazda genuine.
May nakita ako replacement parts na Febest for our mazda sa fitinpart.sg. Is it a good brand?
Sent from my EML-L29 using Tapatalk
January 19th, 2020 04:05 PM #53
January 14th, 2025 10:09 AM #54
Mas ok ba iyong palit Ng bushings Ng lower control arm na orig pa or bili na Lang Ng replacement assembly Ng lower control arm?
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
