Page 6 of 6 FirstFirst ... 23456
Results 51 to 54 of 54
    #51
    Quote Originally Posted by tensazangetsu View Post
    Nakalimutan ko sabihin ninipisan pala ng konting konti ni Velocity yung sa dulo ng control arm nung nikakabit na yung bagong big bushing just to be safe na papasok dun sa butas ng big bushing na saktong sakto lang.
    After 1 week of using it so far so good naman, nag improve yung ride and happy naman ako sa new bushings. Cheers!
    Did you change the ball joint on each arm? That's a part no one wants to go back in & replace later. If so, what brand? Mevotech? Febest? 555? Where sourced?
    The bud's CX5 KE was silenced back to bnew w/ all genuine mounts & arms. The old parts kept & will be rehabbed w/ PU bushes for the next expected swap, 7years away....or hopefully much later.[emoji4]
    Sep 2019
    #52
    Hindi ko pa pinapalitan yun ball joint sir. Nun pinacheck ko ball joint ok pa naman daw. Kahit tumagal lang ng atleast few years sir if may masira ulit na parts sa lower control arm(ball joints or bushing) nasulit ko na din. Pero when the time comes I will replace the entire assembly na with Mazda genuine.
    May nakita ako replacement parts na Febest for our mazda sa fitinpart.sg. Is it a good brand?
    Sent from my EML-L29 using Tapatalk
    #53
    Might be worth a try....both Febest & Mevotech.
    #54
    Mas ok ba iyong palit Ng bushings Ng lower control arm na orig pa or bili na Lang Ng replacement assembly Ng lower control arm?
Best shop in Metro Manila to install lower control arm bushing?
