*dadz
where you able to check his radiator ? baka kasi integrated na sa radiator and coolers meaning, if you look under the radiator meron extra small hose naka kabit doon going to the a/t , Instead of the normal small radiator for a/t. yun sa old accord,revo and avanza ko ganyan ang stock na nakakabit all integrated. kaya pag nag palit ng radiator, pinapakita ko yun old radiator picture with those extra hose and neck sticking out sa ilalim
*g01 or kung sino yun naka matic, check nyo sa radiator pang ilalim ilang hose ang nakikita nyo nakakabit sa radiator.
re: Auxilliary fan, i already ask this sa Casa, sa philippine version, montero lang daw yun kasi dual AC and it is used for the AC cooling coil daw
Pwede din ba gamitin yun aux oem from montero, di ko lang sure kung saan ikabit ang wiring ng aux fan, meron bang water temp sender sensor ang strada para doon ikabit ang aux fan for automatic on/off? baka pwede mo kami bigyan ng diagram ng aux fan mo saan sya nakakabit?
Re: clutch, ano difference ng oem clutch sa racing clutch ? kelan ba usually nag papalit ng clutch? (mileage or years?)
Thanks.
