[SIZE=3]
Sir Nano,
*sir G01 pala earlier made the same suggestions.
Kung hindi engraving baka pwede yung naka-molde? Parang belt buckle? Baka kailangan i-outsource ito sa Thailand or China?
Baka pwede din na resin na lang or something more sturdy?
I think meron foundry sa Rizal Avenue, Caloocan bandang 3rd - 5th Avenue. Yung molde na lang.
Like ko yan, sinugest ko din kay manong yan. Baka CNC machine pwede?
[/SIZE]
Dyno result of the Injectors Performance chip.........
It have 5 micro chip and a micro selector for 1 to 16 preset program.
1 to 4 is use for stock
5 to A is use for turbo upgrade 35 to 45 Psi
B to F is use for turbo upgrade 50 to 60 Psi
Gain from stock is
Corrected HP is plus 78 (209HP) - 131 stock HP
Engine Hp is plus 76 (206 HP) - 130.1 stock HP
Wheel is plus 67 (156 HP) - 88.9 Stock HP
Torque is plus 172 lbs (517 nm) - 345.1 nm
In the graph you will see the smooth transfer of power. This chip increese the injector pressure to give you an optimum performance.
One wire needs to be cut to open the boost cut control and the power to be tap in the ignition.
Our simple Mods
Pasensiya po sobra sobra pala yung post ko nag hung kasi yung connection ko kanina akala ko hindi pumasok...........................
Sino na nagpalit ng pedals? Ang dulas kasi ng stock pedals kapag basa ang sapatos lalo na kapag chuck taylor na pudpod na ang suwelas hehe.![]()
Any suggestions mga bro?
Hi,
Ask ko lang if anyone tried FEDERAL tires or FALKEN?
Ideally maganda Mickey or Nitto...but out sa budget at the moment.
Sana mabigyan nyo ako inputs...need to buy kasi for my ride.
Thanks in advance for the inputs.
