Page 169 of 193 FirstFirst ... 69119159165166167168169170171172173179 ... LastLast
Results 3,361 to 3,380 of 3844
    Jun 2009
    #3361
    Quote Originally Posted by pungdol View Post
    Mga ka-MB ask nmn po plano ko sana mag-change oil sa van natin paano po ba step by step na gagawin before po maglagay ng bagong oil mga sir.. TIA po... Ano po pwede pangkalas sa oil filter first time lng po kc pa-advise naman po...TIA uli...
    depende po sir kung me oil flush kayo ilalagay niyo muna po yoon tapos start for about 5 min. or 3 min and then drain po ninyo ang oil buksan ang drain plug sa ilalim... kung me compressor po kayo hanginan niyo po para mas mabilis bumaba/lumabas yung oil make sure walang tubig na humahalo sa compressor niyo dapat me filter kayo na nag separate ng water sa air, kung wala mag overnight nalang po kayo, yun ang the best hayaan niyo lang po tumulo ang langis mag-damag and then yung oil filter ang ginagamit ko po doon ay kadena lang po... after mapalitan ang filter takpan na po yung drain plug lagyan niyo nalang po ng silicone yung takip ng oil filter at drain plug para sure na walang tagas... and then ilagay niyo na po yung 6 liters na oil ola presto start the engine but don't rev it up let the engine run for a while in a idle manner...
    Sep 2010
    #3362
    Sir pasensya na po. Matagal na po nabasag yung top yung sa akin. Binenta na ata ng kasambahay namin sa junk shop yung rest of the radiator.
    Hehehe, salamat sir otep nagbakasakali lang nman ako.
    #3363
    I just oblonged another pair of Nankang Super Trippers. The 2008 ones, were replaced in December 2012 and the 2009 production ones were replaced today again with Nankang Super Trippers.
    The dealer said that too much tire pressure might be causing the tires to become oblong. I'm just wondering what tire pressures you guys are running. Door placard says 45psi unladen and 55psi when laden.
    My MB100 can only seat a maximum of 4 persons plus one patient in the back area. Is 32-35psi ok? I run on the NLEX everyday.
    Thanks guys. Thank you sir glenn for texting me your feedback on this query.
    Jan 2013
    #3364
    sir oo nga pala... try nyo muna SPRAYAN ng wd-40 yung fuse ng HEATER... FUSE po ha... yung nasa ilalim ng dashboard natin pasenger side... PATI na din yung heater relay... baka may moisture lang... kaya may time hindi gumagana....
    NOTED Sir Glenn, Nakita ko yung parang black na box sa may tabi ng rad at paglagyan ng fluid ng wiper. Gawin ko first thing in the morning before ako punta sa mechanic para ipakita yung tumatagas na naman sa may clutch ung sa rubbercap ata yun. Thanks ulit ;)
    Jan 2013
    #3365
    Sir Otep, Ako po lagay ko sa gulong ko is 45 lahat, weekends akyat ako ng baguio with 7 adults balikan then pag city driving dito sa la union mga 6 adults including me. Maxmiller CX (GT radial) ang gulong na gamit ko po.
    Mar 2013
    #3366
    Quote Originally Posted by jjj_in1056954 View Post
    Sie jjj_in1056954 thanx po sa info.. Takot lng kasi ako magbaklas ng oil filter baka po mabasag yung pinaka casing nya kasi ang sabi ng mekaniko sa good gear plastic lang daw yun. Hindi naman po ba delikado if gamitan sya ng kadena sir? TIA po uli .....
    #3367
    Yes, plastic siya so be careful. Yung sakin may silicone na din sa thread kasi nagka minor leak na over the years.
    Jun 2011
    #3368
    Quote Originally Posted by webieforums View Post
    secondary clutch ba yan sinasabi mo na may tagas nasa ilalim sa may tranny banda? kung ganun palitan mo na ng buo yan sir... nasa 1k ata yan more or less
    #3369
    Yung slave cylinder na may rubber cup nasa Php500 ata sa Banawe pero wala ako nabili na orig. *** Chu ata brand. Ganun din ang naka-stock kina Apic na item. So far so good naman. hehe.
    Jan 2013
    #3370
    Bale yung tumatagas po is dun sa may bandang loob po ng driver side, sa may apakan ng clutch. Nagpalit po kami ng rubbercap nung in-house na mechanic ng 1st owner ng van na nagkataong kapitbahay namin. Nagpalit na rin daw sila ng clutch slave cylinder and rubbercap din last october 5.2012.
    Napansin ko na ayaw nang pumasok ang 1st gear 2 weeks ago so nagpalit kaagad and ang nabili ko na replacement is parang plastic yung ulo niya. Tapos yun na after a week, naramdaman ko nang sumobra ang lambot pag aapak na ng clutch then nagcheck na ako, ayun may tagas na naman.
    #3371
    Clutch master na po iyang nasa taas. Clutch slave yung sa baba.
    Jan 2013
    #3372
    Eto po yung mga images:
    Sep 2010
    #3373
    Sir palitan niyo nalang po yung slave cylinder. Nangyari na po yan sa akin na tumutulo doon sa may clutch pedal......Sir mukhang linis ng engine bay niyo ah. Hehe
    Jan 2013
    #3374
    Quote Originally Posted by gucci88 View Post
    ung slave cylinder ba sir is yung kinalalagyan nung rubbercap mismo? yang kulay black na parang letter t?
    Thanks.
    Mar 2013
    #3375
    Thanx po sa inputs Doc OTEP..
    Apr 2011
    #3376
    Gulong ko 195/75r16. Ang tire pressure ko pinakamataas 42psi lang. Minsan 40psi harap tapos 42 likod, minsan 40psi lahat. Ang tagtag e pag mataas ang air pressure, naiingayan pa ako sa kisame alog ng alog, hehe.
    Mar 2013
    #3377
    Gud aftei mga ka-MB ask ko lng cnu po sa inyo nakapagpalit na po ng room ligth ng MB natin sa LED yung 8watts na flourecent sa first and second row po sa likod? Pa share naman po kung pwede po palitan at saan po makakabili ng LED para dun..TIA po mga ka MB....
    #3378
    Sir bakit mo papalitan? Maliwanag naman yung fluorescent. Hihi. Anyway, pwede mo ikuha kay https://www.facebook.com/plasmaled.lighting?fref=ts ng LED strips. Php150 per 3LEDs ata iyan pero maliwanag talaga. Medyo out of stock lang now. Pero sa kanila ako kukuha ng LED's para sa ambulance. Si Jemson din official installer ng Plasma led so kabisado na ni jemson.
    Jan 2013
    #3379
    Sir Otep, nagpalit na rin po ako kahapon, ang mahal dito nung cylinder na may rubbercap, 1200 ang pinakamababa na nakuha ko. Pag mapunta ako ng manila, diyan na lang ako kukuha ng piyesa na gaya nito pati mga cv boot etc.
    Jan 2013
    #3380
    *Pungdol
    Sir, nagpachange-oil ka na? anong ginamit mo na oil? may cinanvass din ako dito sa amin, ang change oil niya is around 3,000
    500 Pesos per liter. tapos motul na brand ang gagamitin nila.
MB100, Ssangyong/Daewoo Istana [continued]
