Results 1,701 to 1,710 of 5910
February 17th, 2006 03:28 PM #1701
If that's the case, I suggest you do the ff:
Get an extra spray bottle (yung nabibili lang sa supermarket, mga 250ml or so), then pour 1/3 of your WAUD in it, then fill it up with distilled water. Yun gawin mong QD for daily use.
Then use the pure WAUD everyweek post washing.
February 17th, 2006 03:29 PM #1702
AFAIK, you can use a Booster Wax (EO WAUD) on a dry surface. correct me if am wrong guru's.
karl: yup, wash dry then wax. Kahit QD lang pwede na, WAUD is preferably used after washing your car - spray it on your car after you rinse then dry.
February 17th, 2006 04:22 PM #1703
Originally Posted by theveed
Ok Sir, thanks a lot. I'll do that until a QD is available. Do you have a personal preference that you can suggest? thanks again.
February 17th, 2006 05:43 PM #1704
malaking tulong yung CCD talaga. then QD with MF tapos, mag-Spray Wax.
just had some minor dings and some repaint done on my black car. sayang walang wax muna. hehehe
February 17th, 2006 10:58 PM #1707
February 18th, 2006 12:22 PM #1710
byd seal5 dmi. that coolant tank is the same setup like in the fords. plastic coolant lines :twak2:...
BYD Philippines
