Results 2,761 to 2,770 of 3575
- May 2016
- 40
March 8th, 2017 05:49 PM #2761
- May 2016
- 40
March 8th, 2017 06:00 PM #2763
toyota ws is for the newer transmissions. it is low viscosity. it is not backwards compatible with toyota type4. you need type4 equivalent. ano certification ng mobil1 atf? if it meets toyota type4 then its the one you want.
March 8th, 2017 06:02 PM #2764
I purchase original Toyota ATF just to be sure. I hate those brand specific transmission fluid ratings nowadays. Dati it was just Dexron/Mercon.
March 8th, 2017 06:15 PM #2765
toyota makes money by rebranding dex3 oils as typex oils.
dexron vi and mercon lv are the same. they have joint transmission developments the past decades...
- Mar 2017
- 57
March 23rd, 2017 03:27 PM #2766Hi guys, I seem to have a problem with the fuel gauge of my 2010 Altis. When i put gas at night, the gauge is at Full but then the next morning, I start the car and the gauge is now at the 3/4 mark. There is no fuel puddle under the car and no smell of gas inside or outside the car. My car is also parked in a secure place and the car runs smoothly naman. What could be the cause of this problem? Defective gauge?
Thanks in advance!
Sent from my SM-G930F using Tapatalk
March 26th, 2017 01:02 PM #2767
Toyota's old 4AT is sad. Last night I was driving a 10.5G Altis AT on TPLEX and even though it has the same engine as my 11th gen (3ZR-FE, Dual VVTi, 122 hp), it doesn't have the same top speed nor acceleration.
It tops out at 185 kph because that's the fastest I could go in 3rd gear. By the time it shifts to 4th gear, it's out of the powerband already and the needle just won't creep upward unless on a downhill.
The 11th gen with a 6 speed MT does 200 kph on 5th but even after shifting to 6th it still has a bit of juice left to inch towards 205-210 on a flat road.
- Mar 2017
- 16
April 5th, 2017 06:46 PM #2768Good pm mga sir. Tanong lang po. Mahal ba ung maintenance ng bagong altis? Balak sana namin bumili ng altis 1.6G MT. Magakano kaya aabutin pag heavy PMS sa casa? Help mga paps. Tnx
April 7th, 2017 09:31 AM #2769
It's quite affordable to maintain. In the CASA before my 1.6E would cost anywhere from 2K to 4K. Just review the list and remove all non-essentials the CASA tucks on such as additives, decarbon, etc. When i had the service done by my suking tindahan and buy the needed parts from Banawe, the large service stops (40,000kms) did not even cost more than 4K.
April 7th, 2017 09:42 AM #2770
Kay Toyorama? Naalala ko tip mo sa akin before. May ms beautiful doon hehe
Well looks like they're gonna make it easier na to transfer ownership. Timely since I need to...
transfer of ownership / registration cost
