Results 2,721 to 2,730 of 3568
- 52,731
November 7th, 2016 03:36 PM #2721"lifetime warranty".
it means, when the gadget or part malfunctions, its lifetime is over, and thus the warranty.
i don't believe in "lifetime warranties". if i can do maintenance (i.e., may access points), i do it.Last edited by dr. d; November 7th, 2016 at 03:52 PM.
- Dec 2008
- 462
November 12th, 2016 01:16 PM #2723Anybody had their fuel filter replaced? I inquired to speedyfix and he recommend casa for this piece. Any recommended casa if ever? Considering either toyota pasig or taytay as this are nearest to me.
Sent from my SM-G930F using Tapatalk
November 14th, 2016 01:31 AM #2724
Fuel filters aren't expensive so you can have it done in the casa if you like.
When I replaced the fuel filter for my Mazda, I just bought the part from Banawe and had it replaced at speedyfix. Labor was 600 I think, while the filter was around 400.
November 14th, 2016 10:56 AM #2725
Toyota Pasig used to allow bringing in parts. You can check with them if you can buy your own fuel filter. I agree to have the CASA do it if you find it reasonable. The filter is located at the fuel tank. We did the fuel filter replacement on our Vios before at our suking tindahan and the screwed cover can be quite tedious to screw on properly (never tried with my Altis though).
Aside from the fuel filter, it would be good to replace the O-ring to the fuel tank screw cover to ensure the fumes don't get into your vehicle.
- Dec 2008
- 462
- Dec 2008
- 462
November 19th, 2016 02:56 PM #2727So i just came from toyota taytay and the service advisor informed me that there is no need to replace the fuel filter. Apparently the fuel filter is inside the gas tank and the recommendation is to change fuel filter at the same time as the fuel pump.
- Dec 2008
- 462
November 19th, 2016 02:57 PM #2728Which means only when fuel pump gives up.
- Dec 2008
- 462
November 19th, 2016 03:01 PM #2729Moreover the atf is already the ws lifetime atf so there is also no need the ever change atf.
November 21st, 2016 10:10 AM #2730
Re. the lifetime ATF, if for your own peace of mind, go ahead and replace. Just use the original Toyota ATF and a competent shop can do the job. I myself would still change ATF out of habit.
Re. the fuel pump, we've changed fuel filters on our previous Altis and Vios without changing the fuel pump (they are on the same assembly though); after a few years, i replaced fuel filters and the fuel pump on the Vios when it hit 140,000kms.
I think they took over Sept 2023... I remember their event presented the 296 GTB and the Purosangue...
Car Sales Data (2024)
