Results 2,291 to 2,300 of 2560
July 13th, 2015 08:38 AM #2291
- Jul 2010
- 570
July 13th, 2015 09:49 PM #2292Pa check mo servo connector kung loose connector. Pa check kung hindi na bungi mga servo gear.
- Aug 2005
- 2
July 13th, 2015 10:05 PM #2293Yung GLXi '93 A/T ko di nag sshift prang stuck up sa 3rd lang although meron time na normal shifting then balik stuck nman ..ano kaya problema? ..pwede din kaya covert to manual trunny? Tnx
July 14th, 2015 10:57 AM #2294
- Aug 2005
- 2
July 14th, 2015 03:19 PM #2295ATF change 3mos ago ..pina overhaul ko kasi yung radiator dretso na rin palit ATF pro yearly ang interval ng pag palit and last year palit din ako ng filter ng AT.
- Feb 2014
- 13
July 25th, 2015 01:01 PM #2296mga bossing, ok po ba sanden 508 sa lancer el 1996? 4g13 engine
mga bossing, ok po ba sanden 508 compressor sa lancer el 1996? 4g13 engine
- Aug 2015
- 2
August 3rd, 2015 11:44 PM #2297Good pm mga Eggxperts:
Question po about ugong sound sa lancer EL '94. very distracting po siya as hi-way speeds 60kph and up. Is it possibly a wheel bearing problem? Incase po may recommended shops po ba kayo Bulacan or QC area? And how much ang wheel bearing repair/replacement incase? TIA!
August 4th, 2015 10:53 AM #2298
its either :
a. tires are underinflated
b. wheel bearings
c. alignment
but probable is yung wheel bearing. mura lang yan, siguro mga nasa 1.5k isang set nyan.
its either :
b. wheel bearings
c. alignment
- Aug 2015
- 2
August 7th, 2015 04:16 AM #2299
- Aug 2015
- 1
August 10th, 2015 05:24 PM #2300good day, mga brods bago lng ako dto s forum,ask lng sna ako kung anu kya problem ng 95 lancer gli "Itlog ko" good nman un idle nya pg start, pro pg on d way nko ngddrive, my dragging sensation from 2k to 4k rpm pro pg nlagpasan 4k continues na un takbo nya,hnd ako sure kung distributor or fuel injector or pump. tnx s mga advice....
Coolant...
