Results 2,281 to 2,290 of 2560
- Mar 2014
- 901
July 3rd, 2015 10:00 PM #2281SOHC
Valve lash clearance:
Intake = 0.15mm
Exhaust = 0.25mm
Kadalasan mula sa singkit model at sa itlog model.
Mayruon info label sticker under sa hood.
Sent from my UP+ using Tapatalk
- Apr 2015
- 8
July 3rd, 2015 10:52 PM #2282
- Apr 2015
- 8
July 3rd, 2015 10:55 PM #2283I think it was last year when the valves were adjusted. Have an EFI manual transmission....will keep you posted when I get the valves checked. Thanks again!!!
Thanks will take note of this
- Mar 2014
- 901
July 3rd, 2015 11:47 PM #2284EFI model. M/T Lancer.
Tuning up.
Condition: Timing Belt is in good shape. Properly aligned with its mating marks in camshaft sprocket and crankshaft.
>Check and adjust valve clearance to specs.
>Then, set your basic ignition timing to specs., with the correct idle speed.
> idle speed is around somewhat 750 ~ 800rpm at normal operating temperature.
- Apr 2015
- 8
July 4th, 2015 03:41 AM #2285
- Oct 2014
- 3
July 5th, 2015 01:58 PM #2286hello po! im a newbie here and a newbie to my lancer itlog too. does anyone know a mechanic here in cebu cityt that specializes our car?
TIA po.
TIA po.
- Jul 2010
- 570
- Jul 2015
- 5
- Jun 2015
- 5
- Jul 2015
- 1
July 11th, 2015 02:00 PM #2290Hi, just want to ask your help regarding my "itlog".
The engine stalls when AC and headlights are switch on together.
Dati hindi naman ganun and my battery is still new, just 4 months used.
What do you think is the problem with my "itlog?"
Thank you in advance...hehe
2021 Nissan Leaf
