Results 2,171 to 2,180 of 2560
- Nov 2008
- 641
September 23rd, 2014 11:48 AM #2171Chief, I suggest you check the following:
1. Transmission Release bearing
2. Pressure Plate
Kung may extra budget ka pa, pwede mo na ding isabay yung clutch lining para isang bukasan na lang.
- Aug 2014
- 14
September 23rd, 2014 12:26 PM #2172sir jvnj mga magkano kaya aabutin jan pag sakaling papalitan na? thanks
- Aug 2014
- 29
September 23rd, 2014 11:46 PM #2173
- Nov 2008
- 641
September 24th, 2014 10:08 AM #2174
- Mar 2008
- 54,246
September 24th, 2014 01:23 PM #2175and don't forget the labor.
labor alone might cost 1.5 - 2.5 K..
- Aug 2014
- 29
September 28th, 2014 12:45 AM #2176kwento lang mga sirs regarding my glxi. nag change oil po ako kanina using repsol elite, oil filter is vic415 yata. change sparkplugs NGK (kalimutan ko na value). tapos change na din ng high-tension wire as advised by my mechanic friend (may mga lobo na daw at putok putok na yung mga insulators). tapos adjust valve clearance (intake 0.20mm/exhaust 0.30mm). naglagay na din ako ng prestone coolant sa radiator (dati water lang...nagtry lang ako ng coolant)
sarap po gamitin ngayon, ganda ng hatak at pino ang takbo ng makina. nai-share ko lang dahil nakakatuwa kasi DIY lang.
sana may maishare pa po kayong advise kung ano ang magandang gamiting brand or tamang value ng mga adjustment regarding sa makina na makakatulong sa performance nito. peace sa ating lahat!!!
- Sep 2014
- 1
October 3rd, 2014 09:29 AM #2177magandang umaga mga sir.. tanung ko lang po kung posible bang ma recarpet ang lancer glxi93. san po dito sa metro manila? maraming salamat po mga sir.
- Oct 2014
- 1
October 4th, 2014 12:09 AM #2178hello mga sir! ask ko lang kung ano kaya problem pag parang nag choke ang engine in acceleration. particularly sa lower gears at pag medyo matagal na umaandar. newly changed lang ang spark plugs. thanks!
1995 glxi.
- Mar 2008
- 54,246
October 4th, 2014 09:45 AM #2179when the engine is cold, there's an automatic choke mechanism, that gives more fuel to the cold engine.
when the engine reaches normal working temp, the auto choke closes, and the main circuit comes into play.
your description of symptoms suggests you may be experiencing fuel starvation. have the carb checked. baka barado o needs adjustment.
also have ignition timing checked.
- Oct 2014
- 2
October 4th, 2014 04:39 PM #2180Mga sir..lancer 93 gli oto ko.converted n sya sa carb type.electric fuel pump nya sa engine bay..after mga 20 minutes ng gamit tumitirik na.kulang na yung laman ng filter.ung electric fuel pump nag iinit..pinatignan ko n sa auto electrical ok nman daw wiring at ground..may mkkpag suggest b kung anu magandang gawin..salamat.
Coolant...
