Results 2,151 to 2,160 of 3575
November 22nd, 2013 07:38 PM #2151
Mukhang carry naman. 5-spokes will always be a classic an clean design.
- Nov 2013
- 4
November 22nd, 2013 09:26 PM #2152My thoughts exactly, sir. I guess i'll be getting the gen 10.5 1.6V variant too. I hope I get the discounts that you got also.!
Thank you for your insights.
November 22nd, 2013 09:38 PM #2153
- Nov 2013
- 13
November 24th, 2013 11:56 AM #2154Sir san dealership to? Pwede po makuha details ng SA nyo? Interested din po kasi ako sa outgoing model ng altiis 1.6v. Thanks po!
November 26th, 2013 04:14 PM #2155
I agree. For my part, I just want to test fit those 17s to find out kung bagay. He's changed his mind and is looking for some sort of spacer that'll lift the Altis a bit. The only things that come to mind are something like an O-sulee, although this will not really lift the ride, but just prevent the springs from flexing much thereby lowering the ride, and maybe something rubber for the top of the springs. Anyone with ideas where I could get the latter?
And my bad, the damage was on the front bumper. Lower bumper was damaged and so was the lower grille (still on order right now).
November 27th, 2013 09:50 AM #2156
^ Have you tried checking that shop that sells the Japan surplus rims along Q. Ave?
* The O-sullee, I'm not sure but better check if it also keeps the springs from sagging down under load. I know it only cushions spring movements (unlike a rubber lifter).
17's na! Although for sure, may sayad pa rin si front sa steep driveways.
November 27th, 2013 01:43 PM #2157
Nice rims and grille. Hehehe! I actually like the stance of the Altis as is. Not too hard to, um, jazz up. Pogi na. Personally, if it were my car, I'd go with 18s on 225/45s if they fit and match. Much as I like the 17s option, kahit maisukat man lang, i think a rubber lifter is needed. Anyone with a suggestion on where to get 4 pieces?
- May 2007
- 401
- Apr 2010
- 201
December 4th, 2013 09:41 PM #2160Speaking of aircon...tuwing kelan po ba need palinis ang aircon?nasa 20k na kasi odo ko pero di pa napalinisan yung aircon....
Some other dcts, like dun sa mga 1.6 na hyundai & kia crdis, nagka-issue rin bt. Not sure lang if...
2022 Hyundai Creta
