Results 3,151 to 3,160 of 3568
- 52,731
September 27th, 2018 11:41 AM #3151
- Jun 2012
- 93
September 27th, 2018 11:42 AM #3152Ok. I think brake fluid siya.
Sorry sa abala doc.thanks
Sent from my SM-N935F using Tapatalk
- Jan 2008
- 4,726
September 27th, 2018 11:44 AM #3153
- Jun 2012
- 93
September 27th, 2018 12:00 PM #3154Ok so Manual Ttansaxle fluid is the Gear oil.
Nagpa change oil na ako yesterday. Kasama ba siya?
- 285
October 8th, 2018 08:55 AM #3155
- Jun 2012
- 93
- May 2011
- 13
October 9th, 2018 03:16 PM #3157hi guys, recently acquired a 2012 Altis G A/T, everything seems to be ok.
except for this rough sound while im in gear and stepping on the gas.
i dont know where it is coming from, i assume its not from the engine coz i tried revving while in neutral (N) and the sound isnt there.
but when in gear (D) and as i step on the gas, theres a rough sound, though shifting is perfect, no delays, no jerking and everything feels so smooth.
- 285
October 9th, 2018 03:30 PM #3158Does it start making noise once the car starts rolling? Or once shifted to D even when car is stationary?
If it makes noise while rolling, and the noise becomes louder as you go faster, wheel bearings might be seized.
Grinding sound ba or parang something is loose and vibrating?
- May 2011
- 13
October 9th, 2018 03:44 PM #3159specifically sir sound is there once i step on the gas pedal and rolling, yes sound gets a bit louder when i step on the gas more...its like grinding or something rough.
and when the car is cruising naman or on freewheeling (not stepping on the gas) theres no rough sound.
sound is not like loose or vibrating, merely rough sound lang talaga sir.
pag naman po nag shift ako sa D and foot is on the brakes, wala yung sound. and pag naka N naman then i rev the engine, wala din yung sound.
and as ive said, shifting is perfect & smooth naman, i already researched & watched videos about transmission problems but in my Altis those symptoms are not present at all. nakaka paranoid tuloy.
- 285
October 9th, 2018 04:12 PM #3160
Medyo tricky dahil nawawala ang sound once nag freewheeling na, so wheel bearings are ruled out. If they are seized, whether stepping on the gas or not, as long as gumugulong ang auto, tutunog yun. You might want to have the front suspension checked, especially the inner CV joint checked (sa may driveshaft yan). Outer CV joints kasi make noise when making a turn (Taxi na lumalagutok while making a U-turn).
Haven't heard of transmission problems with the Altis, ang common issues lang ng 10th gen are the melting dashboard and the rack and pinion, so most probably hindi sa transmission yan.
Xiaomi E-Car
