Results 1,701 to 1,710 of 1770
August 15th, 2010 09:07 PM #1701
Ayun lang sir. OC din kasi ako sa pagdetail.
I apply Glass Science regularly. I clean it first using the scrub, then banat ng Rain Clear(proven naman ang product na 'to kasi dati ko pa siya ginagamit). So I wasn't expecting it to judder, but unfortunately it did. So I have nothing left to blame but the new wiper I bought weeks ago.
August 15th, 2010 11:05 PM #1702
- Aug 2010
- 1
August 16th, 2010 01:29 PM #1703Mga Sir ask ko lang po kung magkano kaya ang market value ng XUVi 2003??
my mom is planning to buy kasi this month na. may nakita kami kaso may sira ung sa windshield ung gilid cheap of na ung goma, mga 10 inch long. magkano kaya pagawa sa ganun? and ung bumper sa likod may kalawang pero ung bumper lang naman ung may kalawang na nakita namin so far. magkano kaya paayos din nun? tsaka ung sa left door sa 2nd row di mabuksan, pero papaayos naman daw nila un? ano kaya problem sa ganun and kung maayos and maulit uli magkano paayos?
senxa na po dami ko questions, wala kasi kami masyado alam about cars eh.
tnx much
August 16th, 2010 01:58 PM #1704
'03 was the 1st year the XUVi came out. A decent unit should cost around 570-600k.
As to the problems you saw on the unit, those are considered "minor" but would still have minimal cost repairs. The rubber that has chipped off (windshield) would require replacement --- ergo, remove windshield, replace rubber and reinstall windshield. The rust at the rear bumper can be removed if you re-chrome or just have it sanded off then paint with bodycolor. The problem on the rear left door could either be a detached lock mechanism (may only need adjustment but would require to remove door trim) or the childlock is engaged. (if can be opened from the outside but cannot from the inside)
- Apr 2010
- 12
August 17th, 2010 03:14 PM #1709
Hi to all fellow crosswind owners,
Guys, do you happen to know the size of our wiper blades? Both left and right. Ilang inches ang dapat bilhin ko? Btw, pwede ko ba habaan ng 1 inch yung bibilhin ko para mas malawak ang hagod? THANKS
Coolant...
