Results 181 to 190 of 822
November 14th, 2003 11:30 AM #181
oo yung 2.8 pajero exceed mas mahal kaysa bighorn kasi yung tinitignan ko all orig ang lhd steering mahal ng 100K sa lotus ko kaya bighorn ang nakuha ko pero blessing en disguise kasi mas ok pala ang bighorn lotus malakas ang makina at in na in ngaun ang daming trooper ngaun.
November 14th, 2003 08:51 PM #182
ano ba itsura ng ubs 69 na body? ito ba yung body ng trooper bago nila pinalitan yung front bumper n headlights?
- Dec 2002
- 2,335
- Sep 2003
- 14
November 15th, 2003 05:54 PM #184peeps
m selling the stock mags from my 03trooper skyroof edition. these are barely used. less than 400kms on them.
text me 9178145328
thanks
- Dec 2002
- 2,335
November 16th, 2003 02:00 AM #185Just change tyres. Finally had the money to do it. Ang mahal kasi and it's my 1st time to buy SUV tyres. Ended up with Pirelli Scorpions AT. Php 5,300 each sa NH Miller sa West Ave, 275/70R16. Was supposed to get BFG but too much hassle. Php 5,700 sa Ryco yung BFG but no mounting,no balancing, pick up and 245 lang yun. Yup its the best tyre out there coz 3 plies yung sidewalls but for my use(very occasional "real"off road) the Scorpions are more than enough. 6 plies sa top, 2 plies sa sides. Was also suppose to get Yokohama Geolander * Php 4,800 but 1 year warranty lang (Pirelli * 4 years) and 4 plies lang on top. (walang nylon). I'm satisfied with the ride (30 psi). Extra gastos coz pina-press ko all mags (2K). What's with this procedure? Sumama sa otso-otso yung rims ko. Diretso sa alignment, camber (toe in/toe out). Php 1,040 coz alignment lang and front right in-adjust for camber. I have the specs for all of these so I was able to counter check what they were doing sa Servitek(TireHaus, West Ave.) I will post the specs early next week. Reason why I'm preparing the car is because I have plans to go to Capiz via RoRo(Roll On/Roll Off). Pag natuloy I will catalog and post the experience. Thanks!
- Sep 2003
- 14
November 16th, 2003 07:04 PM #186forgot to mention the 03 trooper skyroof edition mags inlude the tires also. they are size 245/70x16. if you have the imported trooper/bighorn i beleive these will fit w/out problems.
09178145328
Tsikot Member Rank 3
- Dec 2002
- 636
November 16th, 2003 07:55 PM #187garyq
Would like to know how they determined that the mags needed "pressing"? I was told, when i had my tires balanced, that the mags may be out-of-round and would eat a lot of weights. They suggested to have the mags pressed first to reduce the amount of lead weights in balancing. Does this really work?
Are alignment specs the same for UBS69 and 73 models? (Actually, the 2 wheel drive trooper is called UBR73)
- Dec 2002
- 2,335
November 16th, 2003 11:06 PM #188jackaroo: they mounted all rims and rotated it. Kitang kita yung otso-otso(wiggle) and the values being indicated sa balancing machine sobrang taas so malaki sobra hahabulin. This is the reason why they suggested to have it pressed. I had it pressed and after that konting konti lang yung hinabol sa weights(tingga).
It worked. Question now is tatagal ba? I'll have it balanced again in 6 months to check.
Alignment specs I'm not very sure but hindi naman nagiba yung chassis and suspension di ba? Anyway they have naman the specs sa Servitek. I guess even for UBR73 coz madami na rin akong nakita na ina-align same as your unit Maganda lang kasi kung alam mo rin yung specs para sure ka hindi ka niloloko di ba?HTH!!Last edited by garyq; November 16th, 2003 at 11:08 PM.
November 17th, 2003 01:27 AM #189
san ba nakikita yung ubs na code, di ko kse alam kung ubs 69 yung sakin. does this mean na inter-changeable ang body ny present trooper ubs73 sa older ubs 69? like bumpers and others?
November 17th, 2003 01:33 AM #190
marvin,
anong mags pinalit mo? hirap kse maghanap ng mags na 6 holes.
balak ko kse mag 17 or 18 kya lang limited ang designs, mahal naman ng mga imported.
