baka me mali sa wiring during conversion. afaik dapat di sya start.
guys, howmuch na ngayon ang market price ng bighorn na 3 doors M/T kung meron man, and the dashbaord is like the latest trooper lumabas... ???
1)Newer models use this system for easy activation, highly dependent on vacuum for switching. Shift on the fly ang tawag you can engage at any speed less than 100kph.
2)This type supercedes the manual hub type (going down and turning the hub locks on both front wheels) Ok sana ito kaso you have to stop to activate 4wd but you dont have to go out and lock front wheels.
3)I think 99 pataas na models only, wala ng locking hubs ito. Nakapirme na wheel
until front drive shaft, sa mid section a vacuum locking system activates integration of front prop shaft to driver side wheel and drive shaft. The problem with this system ay lagi linked ang passenger side wheel to front prop shaft. medyo mabigat at maingay kasi maraming moving parts. kung manual or auto hubs wheels at bearing lang sa harap ang umiikot at wala ng iba, preserving 2 cross joints/spider, 2 cv joints/4 boots.
Sorry mahaba, hope na enlighten ka. Buti di ko sinama TOD.![]()
Happy New Year SQ!
Yes Torque On Demand. This system activates/transfer traction to the front differential automatically once slippage is sensed at the rear via wheel speed sensor. Trooper/Bighorn has a variant that is equipped with this system. Parang LSD applied to the transfer case. Troopers/Bighorns have Limited Slip Diff on the rear.
hello.
where can i buy 2003 side mirror? and where can i fix two lcd tv at the back? isuzu 2003 trooper model. thanx
ano brand nung coil spring mo? Old Man ba? di ko naman intention mag lift. gusto ko lang mamaintain yung height(which i dont know if lifted hehehehe)
SQ, okay naman. pero parang malambot pa rin likuran. mukhang yung coil na ang palitin eh. sayang nga baka okay na yung kayaba kung coil ang pinalitan ko.
locally kay makna-speedlab ang bentahan ng bilstein. 20thou plus yata afair.
dito pala ko nakabile.
http://www.offroadwarehouse.com/prod.../520/sfID3/164
How much should an Isuzu Bighorn AT Lotus cost? Assuming it is in fairly good condition. 3.1 diesel ata yun kaso Japan import (RHD to LHD convert.). Also assume that the conversion is good and that the tranny is in good condition. I'm a relatively low demand driver (mabagal mag drive plus minsanan lang long distance). What should I look out for? I am defintely a noobie in SUVs and Diesel vehicles so any tip/info would be helpful.
I was thinking of buying one being sold to me by a friend. TIA![]()
