Results 571 to 580 of 2560
- Oct 2009
- 5
October 25th, 2009 11:53 PM #571Ask ko lang po when ang next schedule for EB? sana po maka join and maka experience din kami na newbie here...thanks in advance..and thank you sa mga advises sa forum na ito. dami ko natututunan. wag po kayo mag sawa mag advise expecially sa mga bagong tulad namin...salamat po.
- Oct 2009
- 2
October 26th, 2009 09:38 AM #572Lancer GLXi A/T 1994 ko wala ng menor. Pag-start nakapalo agad sa 2000rpm, inadjust/pinihit ko na ang servo bypass but nothing happens..sira na kaya ang servo nito? where can I buy this?
- Oct 2009
- 8
October 26th, 2009 04:49 PM #573
Bro mge, what's the average fuel consumption of your gli? I think mine is a bit on the high side, my full tank only last 3-4 days of Makati-Binan vise-versa. Average ba yun?
What do i have to check to see if medyo mataas fuel consumption ko?
thanks for any advice you could give.
- Oct 2009
- 8
October 26th, 2009 04:51 PM #574
- Oct 2009
- 5
October 26th, 2009 11:10 PM #575Sir nabili ko po servo ko brand new sa El Dorado pasay taft php8000 only. Naka promo po sila nung binili ko. then labor on installation php500 sa labas lang din ng el dorado marami nagkakabit.. Meron din surplus but my advise is go for the brand new para mas sigurado. by the way, if hindi na ka promo ang servo sa eldorado, this wll cost you 12 to 14k more or less. try nyo rin canvass sa nearby autoparts ng eldorado. hope this can help.
- Oct 2009
- 2
October 27th, 2009 09:30 AM #576*char_r
thanks sir..nakabili ako sa ATCO Pasay ng servo kit 16K (genuine), 10.5K kc ang replacement konti lang difference to go ako sa orig.
ippkabit ko n mmya sa mekaniko, sna umokey na..
- Mar 2008
- 1
October 30th, 2009 01:08 PM #577Newbie here. Mine is Mitsubshi Lancer 1996 GLI. Ask lang po kung saan makakabili ng bagong rear shock absorber at magkano? Di na kasi kayang magsakay ng 3 sa likod, laging sumasayad kahit hindi lowered. And isa pa po, saan din po ba maganda magpapalit ng carpet ng car...medyo luma na kasi.
Kung meron sa may Sta. Rosa or Binan Laguna area much better...
Thanks sa forum....very informative...
October 31st, 2009 10:45 PM #578
ATMM (According To My Mechanic): Ang AC daw ang may maximum tolerable rpm po na pag sumubra ay magka high pressure at malamang bibigay ang compressor. Kaya raw pag ang speed ay morethan 120kph na.. off muna ang AC otherwise bibigay ang AC Compressor.. dahil mahina na ang internal parts nito dahil maykalumaan na.. Maybe sa mga bago pa. di naman umi epekto.. let's see.
October 31st, 2009 10:59 PM #579
Hello Itlog owners
, still don't have this high performance car
but If I have, I will try to convert her pcd 100 into pcd 114 for her rims so that I can fit a 6 spokes VR 15" mags. ANG GANDA SIGURO....Pano kaya?
- Sep 2009
- 3
November 4th, 2009 10:49 PM #580
>bro pg pnplitan m ung bearing check mo shaft na pinapasukan ng bearing dapat di xa worn-out, kung worn-out pabuild-up tsaka re-machine. Pag di mo pinaayos kung worn-out babalik ung ingay nya kahit bgo pa ung bearing. please check dapat nsa 0-0 ung tolerance kapag pinamachine mo para may interference fit xa.......gd luck
No, but it was what sounded closest to Bill, bill. Ha ha ha!
