Results 521 to 530 of 2560
August 12th, 2009 04:50 PM #521
tsaka mga bosing, 6km/l gas ko sa 95 lancer ko, may nag advise sakin na mekaniko, palitan ko daw yung carbo ko, any suggestion po?
- Aug 2009
- 1
August 12th, 2009 08:06 PM #522mga kuya may 95 EL din kami. hehe. kaso wala akong alam sa pag-ayos ng sasakyan kaya may tanong ako.
nagdrive kami ng mama ko tapos naka-on yung aircon tapos after 5 mins namatay yung makina. tapos pinacheck namin ipalinis daw yung carburador, eh bago lang yun pati yung air filter mga one month old pa lang. tapos binabaan din yung idle speed screw mashado daw mataas. tapos kagabi naman night driving nagstall ulit yung makina kasi bukas headlights. ano kaya problema dun? taasan ba ulit idle speed screw? hindi ko pa natatry kung gano kalayo aabutin ko pag walang aircon/lights. los banos to dasma pa kasi uwi ko eh. baka hindi ako makauwi. hehehe.
- Aug 2009
- 2
August 14th, 2009 04:09 AM #524Bro i am new here i swap my nissan eccs to a lancer eL aquired 96 is that a good deal already? thanks! i want to join you guys..thanks!
- Aug 2009
- 2
August 14th, 2009 04:13 AM #525Sir pacheck mo ung alternator mo, ung idle mo at higit sa lahat kung my computer box yan malamang don ang tama nyan. sa banawe may kilala akong gumagwa MW auto Electrical and Aircon eto number 4141519 magaling yan sila gumawa ng kahit anong electrical trouble shooting. try mo lang..kasi before nagkaproblem din ako na ganyan sa nissan ko..nagawa nila
August 14th, 2009 09:24 AM #526
- Aug 2009
- 1
August 18th, 2009 12:19 AM #527Ask ko lang kung bakit tumataas ang temp. gauge ko pero hindi naman ako nag overheat. Problem lang is every 2 days naglalagay ako ng tubig sa reservoir. Sabi ng mechanic ko kailangan ng palitan ang cylinder head gasket. Pero wala naman tagas o sigaw akong nakikita. Possible ba sa problem ng auto ko ay thermostat? Thanks
August 18th, 2009 11:22 AM #528
daming possible causes, pero the cylinder head gasket is the least issue. try to:
a. check the underside. may tagas ba ng tubig? kung meron, baka waterpump
b. try also to check for leaks sa mga hoses.
c. replace your radiator cap. baka pulpol na.
d. try also to check your radiator for leaks.
August 19th, 2009 12:30 AM #529
Pag may white smoke pag humahataw, langis ang kinakain ng engine di ba?
what are the things that I need to change?
Medyo nakakainis na kasi pag hinataw yung oto. Dami usok..
August 19th, 2009 10:05 AM #530
Coolant...
