Results 3,641 to 3,650 of 5235
BANNED BANNED BANNED
- 3,790
February 29th, 2008 05:15 AM #3641^^ nope. mine is a 2004 model... it is more like an "EFI" model not a CRDI. A much better fuel system than the mechanical injection pump found in the isuzu fuego.
February 29th, 2008 01:25 PM #3644
Mga Sir May Alam Po Ba Kau Nag Bebenta Ng Stock Na Mags Na Pang Dmax?
February 29th, 2008 02:37 PM #3645
March 2nd, 2008 05:29 PM #3648
hi guys... kakahibernate ko na naman.. hehehe..
i got some questions for Memphis... sir Memphis, i was following (or probably searching and then became confused already!) about your loadplus thread, then I've read na nag OME kana pala na shocks (all four right?) then sabi mo tinanggal mo na ang load plus dahil after nilagay ang OME's as per advise ni ARB. Then you guys mentioned maganda na i-invert and isang leafspring...
medyo nahilo ako finding the bits and pieces of the communications in the long thread so I decided na lang to ask directly from you(hehehe pero via forum pa rin)...
Can you send me the following, maganda sa email: paulbaguio*yahoo.com
1) picture of inverted load spring with the OME
2) how much is the complete OME set? (manila or dumaguete pricing will do)
3) if budget is a constraint, if it possible to install first set muna (example yung front muna, then next yung rear or vice versa) then next na ang next set? and if advisable ano ang recommended na set ang uunahin, harap or likod?
4) for the inverted load spring, is it more on flexing the ride, lifting the bed or para patagtagin?
hehehe sorry, kaka pasok ko lang uli sa forum then dami ko na naman tanong... hehehehe..
thanks in advance...
Guys, kung may sagot din kayo, please do not hesitate.. all your recommendations are welcome, magandang pag usapan incase...
March 2nd, 2008 10:04 PM #3649
mga paps,paano po ba pabilisin yung D-Max natin?so far,all i was able to do was install a cone type filter.is there any way to increase its power,except for buying that chip mentioned here?
- Oct 2006
- 198
March 2nd, 2008 10:36 PM #3650hi, mind you though the chip doesn't increase your speed, like you said "pabilisin", it only makes your engine rev more which increases mainly your torque, it gives you better pull. sa europe kasi mahilig mag tow ng caravan kaya i think this is the sole reason of the chip production. i think d-max without the chip is strong enough,.also not to mention the money it may cost you for the chip.,actualy i have asked someone in youtube, where his gen 2 strada 2.5 hits 180kph, from spain yata. sabi niya sa akin, chips are payne in the ass( yan yong linya pa niya hehe) ang ginawa daw niya is little boost in turbo and injection pumps. ako pala yong jedsebastian don. just see L200 top speed in youtube. calistofax name niya.
