Results 1,381 to 1,390 of 1687
May 15th, 2021 08:57 PM #1381
Super happy with my Daikins so far bro.
I have a 2 hp for my ~35 sqm living room. 1 hp for my bedroom. Total electricity bill ko per month around 1.5k lang.
Total cost for the 2 Daikins was 87k 2 yrs ago kasama installation with extra pipes (around 20 ft).
Magpapakabit din ako for our house naman, 31.5k for the mid-range Daikin (higher EER vs entry level 28k), including first 10 ft installation na.
May 16th, 2021 09:15 AM #1382
Thanks, max ng split is 3hp, bitin pa pala ito.
Sent from my Mi A1 using Tsikot Forums mobile app
May 16th, 2021 09:24 AM #1383
Hindi siguro overworked ang AC sa condo kaya mababa ang consumption and the kwh rate is lower as consumption goes lower. Our next bill is expected at 4k from our 3k average. 2 units 1.5 hp but only around 9 hours each daily. But we use electricity for cooking and washmac 5x a week, aside from the usual home appliances.
Edit add: nag ac nga pala kami sa hapon on weekends lately hehe, ung daughter ko ayaw mag ac sa hapon, kasi malakas ang cool breeze sa room nya
- Jun 2015
- 2,751
May 16th, 2021 09:24 AM #1384^
You'd probably need a ceiling mounted cassette type - the one used in offices.
May 16th, 2021 01:23 PM #1385
using a multi-split A/C (1.5hp living room, 1hp bedroom - single outdoor unit)...
A/C contractor (he's cheapest I found, PM me if you want his details for a possible quote) recommended Daikin over Mitsubishi
Mas mura yung Mitsubishi and outdoor unit was smaller, kaso Daikin uses the newer R12 gas which is also more efficient.
Multi-split Mitsubishi (I think 3 times na kami nagpalit in the past) gamit namin for the longest time so first time using an A/C without "windfree/3D air," medyo may adjustment period pa for indoor parties (pinapatay nung A/C yung candles ng cake)
Kahit walang "windfree/3D air" si Daikin, some positives...
- quiet mode - para di maingay si outdoor unit (kung gusto gamitin yung balcony for yosi break)
- motion detect - mag adjust 2degrees higher yung thermostat kapag walang movement na nadetect si A/C
May 16th, 2021 03:13 PM #1386
Where there are options, I'd stay away from cassettes. Drain requires pump function, lines above the ceiling need extra insulation + gutter system, & the ceiling where 1's installed on is best of washable material or coating. The areas around the vents have the tendency to get dirty. Cleaning of both the unit & the surrounds will take a bit more care.
When line leaks happen, expect access & damage to the ceiling.
Cassettes are wonderful for the 'industrial' ceilingless approaches, though. Air distribution by these can be even & area-dedicated.
- 54,304
May 16th, 2021 05:35 PM #1387
May 16th, 2021 06:21 PM #1388
Dont use a cassette type for a house
Use wall mounted or floor standing
Also larger aircons might require 3 phase power
- Mar 2021
- 636
May 16th, 2021 06:44 PM #1389Best for a house that requires 3hp is still a split type vs floor mount. No need for 3phase power supply sa split, floor mounted needs 3 phase power.
Also, cheaper split type in terms of unit cost and unit cleaning.
We have 2 units of 3hp non-inverter splits for our sala. Yun lang nga, they’re Kolin and sirain sya! 6 years old and we have replaced the capacitors around 3-4x, changed the pcbs once. Now 1 unit just blows uncooled air and emits an error again.
May 16th, 2021 07:59 PM #1390
In that case, I think NCAP is something that they have privatized.
SC (temporarily) stops NCAP
