Page 137 of 169 FirstFirst ... 3787127133134135136137138139140141147 ... LastLast
Results 1,361 to 1,370 of 1687
    Aug 2004
    #1361
    non inverter? Benta at a loss... mura naman mga inverter ngayon
    Sayang din eh. It's less than 2 years old and still quiet.
    May 2007
    #1362
    Luckily found an AC shop nearby that can also repair inverter boards. Tech is a certified ME who works for ARAMCO but got stuck here due to COVID.
    Had my Panasonic 1hp window type non-inverter cleaned and it's a pain in the butt to disassemble. Taking out the fan cover requires moving some thin freon lines out of the way. Removing the control box requires pulling out the leads from the capacitor. Carriers are more cleaning-friendly.
    Bro may I know your location? We also need ac repair - noisy compressor bearing daw sabi nung nag linis.
    Ipa-estimate sana namin magagastos sa repair.
    Thanks in advance.
    Quote Originally Posted by SRGuy View Post
    Thanks in advance.
    Compressor bearing is compressor replacement. Not worth repairing imo. Was the outdoor unit under the sun? Which model btw
    May 2007
    #1364
    Aww sabi nung naglinis nasa 2500 daw - gusto ko sana canvass muna sa iba... Sa fan ba may bearing or same lang un?
    Nasa 2nd floor terrace ang outdoor unit pero di naman under direct sunlight.
    Ah for 2500 that sounds like the condenser fan.
    I just dont trust some technicians.
    May 2007
    #1366
    Same kaya naghahanap ng referrals dito - marcos highway po location.
    Aug 2004
    #1367
    Yeah parang yung dating pinupuntahan namin that insisted on using chemical cleaners para malinis daw ang fins. Also insisted that ice on the coil is a sign of good cooling.
    Jan 2016
    #1368
    Just a thought - does having one appliance lasting many years make the brand "matibay" and conversely, having one appliance conk out prematurely make it not matibay?
    It feels so anecdotal and there will always be bad eggs in any brand/model. Pag mataas failure rate as a percentage of a large sample size, yun lang yung talagang definitive na lemon talaga - like Ford's DCT. But even then, does not mean that all Fords are bad, because Mustangs are pretty well-built cars.
    So typically I put more weight to people who deal with hundreds of appliances as opposed to paisa isa lang. Which is why I went for Daikin for my aircon - my contractor has installed countless Daikins for his clients with no issues so far. Si travs na contractor din, highly recommended. Then it's the second largest aircon manufacturer (next to Carrier, which has an advantage because they also sell a lot of window-types), so that counts for something too. And on the flipside naman, as mentioned previously, a friend who deals with appliances every day and even works for Samsung doesn't recommend it so I crossed it off my list even if it's relatively cheaper than Daikin or Panasonic. But even amomg these professionals who deal with lots of appliances may kanya kanya ding favorite - wala namang purely objective measure talaga of failure rates across models and brands across the world.
    At the end of the day, to each his own of course - everyone has a different decision tree and criteria when buying appliances. [emoji846]
    Hi Just, how's your Daikin? Considering having one installed also in our sala dahil sa sobrang init, how much na kaya ang going price ngayon, complete with installation? 1.5 hp or 2.0 hp? Area is around 40 sqm, but with 2nd floor na around 20sqm.
    Sent from my Mi A1 using Tsikot Forums mobile app
    Jun 2005
    #1369
    40sqm? Bitin na bitin 2hp dyan.
    Yung basic na 2hp inverter ng daikin nasa 47k last time
    Sent from my MI MAX 2 using Tsikot Forums mobile app
    #1370
    tama bro, i got 5 brands installed in my place (Panasonic, LG, Carrier, Sharp, Samsung). ganyan din sa car brand hindi iisa
    itong biggest air-conditioning contractor dito sa eLyU is highly recommending hitachi brand. they carries all aircon brand naman kaya depende na lang sa preference ng kliyente. sirain nga daw ang Samsung pero meron kami 1-unit at maayos pa naman ang takbo sa ngayon.
    mas tipid daw ang power consumption ng hitachi at 2 daw ang board nya. so bale mas madaling magpalit pag nasira. sabi sa akin... pansinin mo lahat ang mga aircon units ng 7-11 na naka-install puro hitachi that runs 24/7 (totoo nga ito dito sa amin)
    nung tinanong ko ang price ay medyo pricey sya. kaya non-hitachi brand ang pina-install ko sa kanya!
    ang pinaka-importante sa lahat sa akin ay yung reputable installer at proper maintenance. pag maayos ang installation siguradong tatagal ang aircon unit mo.
Split Type Aircon: Which is best?
