Page 166 of 169 FirstFirst ... 66116156162163164165166167168169 LastLast
Results 1,651 to 1,660 of 1687
    #1651
    in my opinion,
    splits are usually designed, to operate out in the open.
    splits make higop ambient air from vents in the housing, pass them thru cooling fins to make them cold, then spew them out to the room.
    enclosing them... they just higop the already cold air in the enclosure... the room does not benefit maximally from the cooling, because a significant part of the spewed cold air are only circulated within the enclosure.
    but they do result in silent operation, if that is the house owner's objective.
    Yup that's why I originally cited a theater/listening room.
    There are ways to engineer around the problem like having an exhaust duct at the top of the room that plumbs back into the top of the area housing the indoor split; or simply having a taller enclosure with separate intake duct at the top to better utilize natural convection in the room.
    Quote Originally Posted by carxynogen View Post
    Also another negative ng covered setup na yan.
    Hindi ba magkaka moist yung grill due to cool air coming from AC vents?
    OK lang sana if plastic yung cover grill but if painted wood, it will deteriorate in time if laging nagkakamoist.
    On a well-running A/C this shouldn't be a big problem. A/Cs remove the humidity from the air and it falls down the drain pipe.
    #1652
    about that drain,
    someone once said, to make the drain hose/pipe extra large, i.e., larger than factory spec, so as to avoid it from getting clogged in the long run.
    just put a mesh at the end, to prevent small animals from crawling into it.
    Jan 2009
    #1653
    Got a little busy this past weekend.
    For months now, one of our outdoor units have been making intermittent screeching noises. It's quite far from the living spaces and wasn't actually bothering anyone so I thought it was something benign and didn't gave it much thought. Besides, the A/C was getting long in the tooth (12+ years) and I thought it was just something ageing machinery does.
    But then a few days ago, the indoor unit started to shutdown after a few minutes and throw out an error.... with the Power LED blinking red.
    Fearing the worst, I went out to look and discovered that the outdoor fan motor has seized up. My guess is that the system detected that the evaporator coil was overheating and it's what caused it to shutdown. I tried to rotate the fan by hand and it began to turn again, worse noises and all. But at least it was no longer shutting down.
    Conceding that the temporary 'fix' wouldn't last, I removed the fan motor and disassembled it down to its rotor. I found that the aft bearing was all mangled up. While the front bearing was still technically ok, I decided to replace both.
    Aft bearing:
    Front bearing:
    Went to a nearby bearing shop and bought a pair of SKF 6202-2RSH bearings:
    Now, it runs and sounds brand new.... for its age.
    All in, I spent less than P500.
    Lesson learned is to not dismiss symptoms and abnormal operations, however benign, that can end up inconveniencing or costing you more later.
    #1654
    Aft bearing:
    Front bearing:
    Hello oj, OT lang how's the performance nun genset mo that you have converted to run with LPG?
    Saan mo nga pala nabili yun regulator and ano ulit yun steps paano mo ginawa. Thanks.
    Jan 2009
    #1655
    So far, so good. Haven't used it for a great length of time because we don't get many power outages longer than 20 minutes. But I still exercise it for 10-15 minutes every 2 months or so, just making sure it starts in an actual emergency. I alternate between gasoline and LP.
    You can use any LP regulator that is used on stoves. What you need is the demand regulator that is one-piece with the carb. Less than 2k lang yung assembly and it's a bolt-on for the most part. You may need to adjust the air/fuel mixture for both gasoline and LP to work with your generator, but that's about it.
    #1656
    Aft bearing:
    Front bearing:
    ... and i thought all along, these were throw-away motors...
    TIL.
    Jan 2009
    #1657
    TIL.
    They are very much serviceable as far as the bearings go. The only reason to replace the whole thing is if the stator winding has burned out or the rotor/shaft is damaged or bent.
    Brand new is in the 5-7k range, while 2nd hand costs around 2-3k.
    #1658
    Aft bearing:
    Front bearing:
    SKF are very good bearings. Buti may nakuha ka. Hopefully not counterfeit though.
    Jan 2009
    #1659
    Same thing I heard. The codes checked out naman using the SKF authenticate app.
    Mar 2004
    #1660
    Is anyone here using Samsung Windfree airconditioner? ... How is it? ...
Split Type Aircon: Which is best?
