Page 155 of 169 FirstFirst ... 55105145151152153154155156157158159165 ... LastLast
Results 1,541 to 1,550 of 1687
    #1541
    i wish the owner would chime in and assure us,
    "guys, i read your concerns and theories. i assure you, lumamig ang aircon namin nung kinabit namin yang venting aid na yan."
    With that fix, its not exactly engineering.
    Obviously the condenser fan has to work extra. More work means higher power consumption. MTBF for the fan is lower by a higher margin.
    Aug 2004
    #1543
    Baka nagreklamo ang kapitbahay hehe
    Sabi nung installer ko may mga cases daw ng away dahil nakatutok ang condenser fan sa bintana ng kabilang bahay [emoji1787]
    Sent from my SM-A605G using Tapatalk
    Feb 2019
    #1544
    It looks to me like the deflector is not only useless but also impedes air flow compared to none. If the deflector wasn't there, won't air also escape sideways aside from upwards?
    Nope the air will flow directly into the wall and then bounce back probably some air would go sideways that's why deflector is installed to make way for the air to go upwards.
    Feb 2019
    #1545
    That's not efficient. No other location?
    Im not sure with the owner but probably there will be other options for condensing unit location but farther than this one.
    Jun 2015
    #1546
    Has anyone here tried those "fin combs" sold online? It's supposedly for straightening those fragile aluminum fins. I'm not sure if it's going to be effective or cause more problems.
    I noticed one of our ACs have several bent fins which I think causes quick build up of that white gunk that eventually clogs the drain.
    #1547
    i haven't tried it myself, but it seems logical to...
    try an ordinary suklay whose teeth are "appropriately spaced".
    they are probably cheaper and easier to get.
    Apr 2012
    #1548
    What's the difference sa Standard na Inverter AC vs sa full DC inverter?
    Sent from my SM-A507FN using Tapatalk
    basic inverter ac only have the compressor working on dc, while its other components like blower fan, outdoor fan are ac.
    full dc means all major components are dc,
    Sep 2010
    #1550
    & full dc means it would be more expensive but it consumes less electricity?
Split Type Aircon: Which is best?
