Results 1,051 to 1,060 of 1687
- Jun 2005
- 3,774
December 29th, 2018 12:27 PM #1051During the time the LG compressor went kaput, downtime was 3 weeks.
Main problem ng split type is workmanship. Yung fittings madalas nagkakaleak ang nauubos right after the 3 month install warranty. Those flarws also act up sometimes. You dont encounter these problems with wondow types.
Im planning to replace the split type with window.
Sent from my MI MAX 2 using Tapatalk
December 29th, 2018 12:45 PM #1052
Even assuming 3 weeks, it's not that big a deal since I don't need the aircon all the time. 49 weeks of better looking and more efficient operation still sounds like a good tradeoff.
And that's also why I want to get a higher quality aircon - to avoid breakdowns in the first place. My National aircon in my room hasn't needed any repairs since it was installed 3 yrs ago, and the aircon is 20 yrs old and has moved 3 houses.
December 29th, 2018 12:46 PM #1053
Keys to splits are to have the least number of seams, have oversized drains & the shortest possible route from indoor to outdoor. Those are where leaks pop 1st.
Ironic how the love for window usually develops from the hate for splits....Love at 1st sight or sound can be shortlived.[emoji852]
- 54,202
December 29th, 2018 01:26 PM #1054experience is the better teacher.
'swhy there are voters for split, and there are preferers for window.
December 29th, 2018 02:04 PM #1055
The nice looking Panasonic window type inverter doesn't fit my pre-cut enclosure. 500mm cutout vs 560mm width for the Panasonic. The Hitachi fits but looks hideous.
Tapos magkalikod lang talaga yung split type and condenser so very very short tubings, so less chances of leaks. Really leaning towards split type now.
Just deciding on the brand. Will visit a store later, eto prices nila online (free installation):
LG - 27k
Panasonic - 29k
Daikin - 30.5k
Sent from my SM-G950F using TapatalkLast edited by jut703; December 29th, 2018 at 02:06 PM.
- 54,202
December 29th, 2018 02:07 PM #1056my colleague had house originally split-airconed.
had to destroy part of the wall after a few years, as they had to look for the leak. the straight, un-coupled tubings were (belatedly bad decisionedly) embedded inside the wall, about a dozen feet or so. the other half of the split was just outside the wall, sitting on the terrace.
window type na siya ngayon.Last edited by dr. d; December 29th, 2018 at 02:11 PM.
December 29th, 2018 02:20 PM #1057
December 29th, 2018 02:22 PM #1058
December 29th, 2018 02:36 PM #1059
Oh, laminates. ...Careful w/ spills. They can bloat. Have you seen how service guys clean splits? They protect the wall with a sheet of plastic curtain that funnels onto a pail. That's the collector for the water they spray onto the indoor unit. Accidental spills aren't uncommon. And, should the unit leak, expect the floor to be collateral damage. Just pay a lil extra attention.
All that said, if you're still leaning split, stay w/ Daikin; limit your weld seams to 2, if possible; line an oversized properly sloped drain; insulate well & do not embed em lines. Oh, ideally no fixed mounted appliances under the wall unit....And don't ever go cassette....You should be ok. If you fear the hassle, you can cut the journey & go Hitachi window....that's a well rated one.[emoji4]
December 29th, 2018 02:42 PM #1060
Ah ok. So Wala pa Lang locally released na delicą dito. Pinapakyaw kasi Ng mga outdoor lovers...
Mitsubishi Philippines
