Page 79 of 169 FirstFirst ... 296975767778798081828389129 ... LastLast
Results 781 to 790 of 1687
    #781
    Quote Originally Posted by JJB View Post
    Our house contractor placed embedded AC tubings inside the walls and drain into the regular pvc downpipes. They used cpvc or pex yata which they say is much stronger and minimizes leaks compared to regular pvc pipes. Sorry dont know the exact material they used but usually for high pressure water daw. It’s been 3 years and hopefully they never leak.
    We're talking long term here, not just a few years, sir. PPR is preferred over ųPVC anytime. Not just material, size matters, too. Drains must be oversized beyond an inch in diameter as they'd be prone to clogging. Water+dirt+dust=jelly sludge.
    The options I shared were concocted after seeing fellow designers, friends complaining about the servicing, maintenance of splits years down. Window is a lot simpler.
    Nov 2007
    #782
    PPR nga ang pipes ginamit. Thanks for that. Actually it's the contractor who insisted to have it embedded, while I wanted it to be external para madali lang i-repair just like you said. I'm also concerned long term-wise.
    As for the AC units, mas madali nga to service window units but the deal-breaker is the noise that window units make. Mas tahimik talaga ang split ACs, inverters or not.
    Meron ba window units as quiet as split ones?
    Mar 2004
    #783
    Carrier makes 2.0 HP window inverters ...
    Nov 2017
    #784
    Proper installation lang sa mga spki type aircon walang shortcut tatagal unit mo na wala problema. I've been using split type aircons more than a decade now and wala problem. Maingay window type acu even yung inverter type and mas tahimik yung split type.
    #785
    Hehe....there will always be pros & cons. There are less noisy window units, though.
    If splits are desired, here are some tips:
    -Find the shortest route from room unit to the condensing for max efficiency. The condensing unit must be on a well-ventilated area & accessible to service. Though all-weather, delay rust by sticking on a sheet of extra rain protection, like polycarb or acrylic.
    -Insist on larger PPR drains beyond an inch in diameter with the least bends & distance to larger plumbing. P-traps are best installed on joint drains to prevent odor contamination. Common leaks are from clogging. Water & dirt will gel.
    -Install room units on perimeter walls to avoid routing lines thru ceiling. If ceiling routing is unavoidable, lay the properly insulated tubes & pipes on a sloped gutter tray all the way to the exterior outlet. This will handle condensation drips. Leaks & electricals can be a nightmare to sort.
    -Avoid cassettes when you can. Drain is by pump, not gravity. And, ceilings will tend to have blow marks & finger prints from service.
    -For easiest trouble shoots & swaps, opt for exposed lines over embedment. Just cover the unsightly w/ removable plastic or aluminum C-sections.
    True, proper installs, attention to detail, following standards & using reliable brands can give trouble-free split enjoyment for a long time. Taking measures to address known contraindications are just ounces of prevention that will outweigh the pounds of cure.
    Nov 2017
    #786
    +100 sir[emoji106] [emoji106]
    #787
    Quote Originally Posted by maxpedition View Post
    Just sharing, sir. Thanks.
    Note that free-install offers are contracted out. Discuss & insist with AC vendors & their contactors the detailed install specs & procedure. Chances are they'll request a lil add-on. Negotiate the cost, never compromise the specs. Some will contradict, sweet talk, convince & guarantee you with their 'experience' & 'standard' practice....the GOOD ones will agree with the sound request of proper install & materials.
    #788
    as trav says,
    wag maniwala na weather-proof sila.
    install a protective roof.
    and make sure just how much all those tubings will cost you. sukatin nang ma-igue at linawin ang condicciones ng pag-gawa.
    #789
    as trav says,
    I have one split type A/C with approximately 40+ feet copper tubings installed from one part of the house to the other side.
    #790
    well, if it can not be avoided...
    errr...magkano po siningil ng nag-kabit, por metro?
    my colleague chose beauty. the tubings were buried in the wall.
    hayun, when it started leaking, the repair bill was also a beauty.
    hindi na niya pina-tago sa loob. pinalabas na lang niya.
Split Type Aircon: Which is best?
