Results 771 to 780 of 1687
March 31st, 2018 10:28 PM #771
I'd rather look for a nearby service center than SM or any other appliance center, and have them install it.
This is much cheaper and maintenance should be fairly easy as you can call them anytime.
The nearest service center around our place is Samsung. I'm a bit worried after reading some problems encountered with this brand. It's only a year old.
March 31st, 2018 10:55 PM #772
Am beginning to rethink the HVAC system I have to install. Might just go with window inverters instead of split types. Just 3 things bothering me about window inverters.
1. They don't look as good as split types
2. The vents are vertical and small. Airflow swath would probably be limited.
3. Up to 1.5Hp only. I would need to install more units vs split types.
If only they were a bit cheaper pa hehe.
I saw those inverter Hitachis before. Felt like they priced them out of the market just because they were the only window inverters.
Panasonic inverters are listed at only 31,xxx for 1Hp and 34,xxx for 1.5Hp at Anson's. I'm sure they're cheaper for COD.
March 31st, 2018 11:18 PM #773
March 31st, 2018 11:44 PM #774
True, not as pretty, but they're excusable. Vents & cooling are fine if the size matches the room.
We always advocate Function & Low/Easy Upkeep in the structures we design & do. Window wherever we can over Split. Maintenance & swap downtime are DIYable easily.....We also don't embedded tubes & drains in concrete. Tube insulation can deteriorate & cause all sortsa trouble. With condensation & leaks, damage on finishes, precious wood floors & trims can be irreversible. Don't worry about form, exposed pipes & tubes can be made to look bearable...here's a sample of window & split applications we usually do....No drips, no mess.
- Nov 2017
- 1,748
March 31st, 2018 11:58 PM #775Sorry bro pero hindi bagay dun sa house yung window type lalo na yung frame support na ginamit medyo awkward. Easy to maintain mga window type pero nakakasira lang ng facade design mo. Wala naman problema sa mga split type baka hindi lang maayos kabit ng installer mo baka tinipid ka sa materials.[emoji1]
April 1st, 2018 12:05 AM #776
I don't disagree....that's why the window is on the rear of that house.
Once trauma of AC troubles hit, one can appreciate these preventive measures more. Many who are technIcal & OC, esp those who've seen leaks as ACs age, often opt for the practical. Oh, the frame support came with the Hitachi unit, sir....I don't like it either, but better safe than sorry.[emoji4]
- Nov 2017
- 1,748
April 1st, 2018 12:11 AM #777
April 1st, 2018 12:22 AM #778
Insulation is pretty much standard procedure, sir. I've been dealing only with the best & most experienced AC providers & installers....& even they'd push for exterior routing of insulated tubes. None thru ceilings nor embedded in walls, if possible. ACs will need periodic servicing, lines can go, refrigerant can leak, insulation will deteriorate over time. Units die & when swap time for splits come, they'll likely need new lines. Going the extra mile can help keep the structures looking new longer, prevent headaches for owners.[emoji4] Just sharing.
April 1st, 2018 12:46 AM #779
Our house contractor placed embedded AC tubings inside the walls and drain into the regular pvc downpipes. They used cpvc or pex yata which they say is much stronger and minimizes leaks compared to regular pvc pipes. Sorry dont know the exact material they used but usually for high pressure water daw. It’s been 3 years and hopefully they never leak.
April 1st, 2018 12:51 AM #780
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
