Results 161 to 170 of 1687
Tsikot Member Rank 4
- Jun 2006
- 2,605
March 27th, 2012 08:17 PM #162I have 4 Sanyo 3 TR units in my store, purchased brand new and installed in 2009 . I do not recommend them. Sakit sa ulo. Malimit may problems. If I can do it again, I'll go with Carrier or Panasonic.
Tip: look at the EER and the rated wattage of the aircon. If you will run the aircon 8 hours a day everyday, buy inverter type with the highest electrical savings.
- Jun 2006
- 2,605
March 27th, 2012 08:34 PM #163Answer: it depends. If you need to cool the whole 3000 sqm area at the same time like a hallway or ballroom then go with centralized. If your area is divided into small rooms like offices which are used at different times then you may consider split types.
Take into consideration that for a centralized unit, you will need ducting and air handling units and/or fan coil units. This will add a lot to your installation cost. A chilled water unit will also need a cooling tower, chilled water pipes, water pumps, motors and chemical treatment. Have your designed run a projection how much it will cost to buy and install all of the items and how much to run and operate it.
For 3000 sqm you will need about 150 TR. You may want to look into aircooled chillers. They cost a little more to run than water cooled chillers but dont need cooling towers so its a trade off. Your designer should be able to compute and give you its pros and cons.
For split type units, you get flexibility since you can rn only what you need. No need to operate a big chiller when you dont need to cool the entire area. Trade off is you will have a lot of condensers and a lots of units to maintain.
As always, dont just look at the initial cost but also take a loooong look at operating and maintenance costs. The initial cost is a sunk cost but the operating and maintenance will be with you forever. Well as long s you use it.
There are high efficency chillers available. Like inverters, they cost more initially but youget a ROI after some time. There is also a system that is similar to a multi inverter system (forgot what its called). Basically, its like a big split type inverter with multiple indoor units.
April 23rd, 2012 10:47 PM #164
Wow, so many things to consider. Thanks for your insights bro. Actually I have already talk with some aircon contractors/suppliers about this and the initial costing for using a centralized aircon is indeed very high and you need a lot of space for the chillers, ahu, cooling tower etc. It will consume some of your floor area. I'm now leaning towards split-type A/C.
- Jun 2006
- 2,605
April 23rd, 2012 11:55 PM #165With the recent price inc in electricity, I suggest you get inverter units or VRF.
- Jun 2011
- 8
April 29th, 2012 03:42 PM #166guys, ano experience nyo sa LG at Samsung?
which would be a better brand for split type inverter? or strongly recommended talaga and panasonic?
- Jan 2006
- 203
April 30th, 2012 10:28 AM #167
- Jun 2006
- 2,605
April 30th, 2012 12:37 PM #168So far ok naman ang samsung inverters sa office ng kapatid ko. Malamig and matipid sa kuryente.
June 21st, 2012 10:37 PM #170
pareho ba inverter yun carrier i-power and xpower series? alin ang mas ok sa dalawa?thanks
Parang 1999 ata last year ng 4wd variant sa taiwan(LHD) so baka subic na yan narito saatin
Mitsubishi Philippines
