Page 24 of 48 FirstFirst ... 1420212223242526272834 ... LastLast
Results 461 to 480 of 954
    Not a software issue. Have already checked everything you mentioned.
    I seem to have found the issue though - I'm constantly hitting the 100 deg C limit of my processor at max load so it throttles down and thus hampers performance:
    Solution: Undervolting via Throttlestop. 90mV undervolt on the processor and 30mV on the GPU. My temps dropped by an average of 10 degrees even at full load:
    Laptop now keeps at higher Turbo Boost for longer, even maintaining peak clock speed of 4 GHz.
    Was gonna reco throttlestop if high temps were found. 15w(ish?) cpu and its still overheating. It could be the thermal paste. I got some tools and thermal paste for a laptop upgrade for one fam member.
    #462
    Yan yung nuclear option ko - change the thermal paste. But I would assume an X1 Carbon would be well-built enough not to need thermal paste replacement in less than 2 years.
    Thankfully nasolve ng undervolting.
    Apr 2012
    #463
    Got a new upgrade of PC.
    AMD Ryzen 7 3700x
    Msi B550 Mortar
    Samsung 511gb ssd
    WD 2tB HDD
    kulang pa ng parts, as delayed ang deliveries.
    Pang light task lang and some gaming
    Sent from my SM-A507FN using Tapatalk
    If you want you can borrow the tools and have some arctic mx4. Dropby lng sa flair.
    AMD Ryzen 7 3700x
    Msi B550 Mortar
    Samsung 511gb ssd
    WD 2tB HDD
    Excellent board choice
    #466
    AMD Ryzen 7 3700x
    Msi B550 Mortar
    Samsung 511gb ssd
    WD 2tB HDD
    How much abutin ganyan setup? Kaya ba nyan ang MS Flight Sim?
    Signature
    Apr 2012
    #467
    Kaya naman.
    Basya goods GPU pati RAM.
    Namimili pa ako ng GPU pero I'll go with Nvidia over AMD GPU
    Apr 2012
    #468
    Future proof na [emoji16]
    Ngayon lang ako ulit nag AMD after 14 years siguro.
    Atlhon 64 last na AMD ko, tapos Intel na.
    Pentium 4, Dual Core, Core 2 Quad, i3, i5. Then eto ngayon Ryzen.
    Susprised that they had this type of CPU na.
    #469
    Needs video card to run flight sim. Add 20k to this build to run flight sim with a RTX 2060
    #470
    x570 board? which psu? all from mwave?
    scorptech yes x570 gyga gaming x..
    specs
    gyga x570 gaming x
    8gbx2 corsairs
    r5 3600
    650w HX corsair
    LianLi 011d
    lian li fans
    corsair rgb xt 360
    500gb samsung m.2 nvme
    currently on 285gtx ...still waiting on 3070
    #471
    my built a decade ago
    Quote Originally Posted by ozcity View Post
    specs
    gyga x570 gaming x
    8gbx2 corsairs
    r5 3600
    650w HX corsair
    LianLi 011d
    lian li fans
    corsair rgb xt 360
    Those 285s have the worst coil whine when overclocked.
    Aug 2004
    #473
    Finally completed the desktop last night. Surprisingly it was a 1-click start
    Ryzen 3 3100
    Gigabyte B450M DS3H - packaged with the CPU
    2x8gb Ripjaws 3200
    Gigabyte 1650 Super Windforce
    Kingston 500gb M2 SSD
    FSP 80+ PSU
    Thermals are a bit compromised because the PCI WIFI card is blocking 1/4 of one of the GPU's fans. Shouldn't be a big issue though. The room it resides in has AC anyway.
    Came in under my 30k budget with a cheap case that included 3 RGB fans. Got all the parts from two stores in Glorietta.
    scalpers are helping with decision making
    I was trying to research keyboard, especially mechanical ones. Langya, lalim pala nito, may specs din, such as hot swappable, red switch, blue switch brown, etc.
    Aug 2004
    #476
    We have 3 mechanical keyboards: my wife is using Romer-G switches; I'm using Cherry Reds; and my youngest son is using Outemu Blues. Maingay daw yung Outemu Blue and halata na naglalaro sya madaling araw so he's trying to offload that to his older brother and getting something quieter. We're looking at either Outemu Reds or Browns as budget options.
    Malalim yan pero satisfying gamitin. Sabi nga ng isang YouTuber "once you go clack you never go back".
    Mar 2013
    #477
    Finally after 3 months...my warranty replacement of my defective memory was honored By Dynaquest. Grabe sobrang hassle to get warranty honored.
    2x16gb 3600 mhz gskill rgb ram.
    Jan 2009
    #478
    I don't game that much but the keyboard I wanted had to be backlit. I went for the Logitech G413 which happens to be a gaming keyboard. It uses Romer-G tactile switches.
    A lot of people say that the Romer-G is similar to the feel of a Cherry MX Brown switch.
    Cherry MX:
    Red: Linear with no bump
    Blue: Tactile with a bump
    Brown: Somewhere in the middle of Red and Blue
    Aug 2004
    #479
    What happened? Naka gskill din kami pero 2x8gb 3200 mhz lang. Got them from PCX. Kakatawa ang packaging parang benta lang sa tiangge haha
    Aug 2004
    #480
    Perfect ang G413 for my wife's office. Di sya scandalously loud and looks semi-pro pa rin dahil red lang ang backlight. Naiinggit nga mga clients nya especially seniors dahil umiilaw daw pwede gamitin sa gabi.
Computer and Laptop Tech Thread
