Results 571 to 580 of 954
December 25th, 2020 09:44 PM #571
- Jul 2009
- 3,604
December 26th, 2020 12:27 AM #572For plex, overloaded na ba yung ganiyang setup?
No experience using that but the IGP / quicksync should help a lot hindi ba? hehe
EDIT: Remembered that the 1050TI and all the other NV consumer cards are limited to 2 simultaneous transcode streams before dumping the rest of the load back to the CPU...
If that's your bottleneck, a quadro card or a driver hack (if exists for your OS/platform?) should allow more concurrent streams.Last edited by mda; December 26th, 2020 at 01:01 AM.
December 26th, 2020 09:34 AM #573
Yup, I know about the limitations. I haven't found it necessary to hack the driver. Of course I've been waiting for a bargain P2000 to come along but after a couple of years, they're still expensive and hard to come by.
Anyway, both the Intel Iris Pro Graphics P6300 (IGPU) and the dedicated 1050Ti, together with the CPU, do pitch in to do the transcodes. That said, Nvidia's 2-stream limit is not too big of an issue for me. At least, not yet.
CPU, GPU 0, and GPU 1 utilization while plying 4 or 5 streams:
- Jul 2009
- 3,604
December 26th, 2020 10:11 AM #574
December 26th, 2020 11:11 AM #575
True. But of course, it depends on the media and the playback device. In the test above, I forced all streams to transcode to force the CPU and GPU to work their arses off. In reality, however, if the playback device supports the media type, it will use Direct Stream or at most Direct Play.... which consequently consumes very little processing and is only limited by the storage IO.
February 4th, 2021 07:08 PM #576
Anyone have monitor that can turn into portrait? I'm thinking of buying a cheap one for viewing source code.
February 4th, 2021 09:32 PM #577
I used to have a Dell IPS monitor from long ago (U2412M) that I sometime use vertically for spreadsheets. The mount is rotatable for vertical and horizontal use.
I gave it to my brother na, this is his current WFH setup:
A used Dell IPS monitor is about 3k nalang these days.
Sent from my iPhone using TapatalkLast edited by jut703; February 4th, 2021 at 11:18 PM.
February 6th, 2021 03:29 PM #578
Thanks for the tip. I'll try to look for that one.
February 8th, 2021 12:24 PM #579
Just sharing what I did with my old PC hardware... from E-Waste to E-Art.
I still have a lot of old, defective, or otherwise obsolete hardware I might put up and make eyesores into something cool.
- Feb 2014
- 2,705
February 8th, 2021 01:19 PM #580
I think we can agree to disagree on this. But I'm going to nitpick the point about deionized...
Coolant...
