Results 1 to 10 of 10
- Oct 2008
- 380
May 29th, 2010 09:39 AM #1ano mas maganda? mag continuous ink system o bili na lang akko ng refillable ink cartridges.
ang ayaw ko lang sa continuous, me tank & hoses na nakikita sa labas ng printer. pag refillable ink cartridge, parang naka original set up pa rin.
when i went to cdr king ysterday mron n pala diy na refillable ink cartdge for epson t10.
any comments??
thanks
May 29th, 2010 02:10 PM #2
I have gone through the use of refilled cartridges and currently using CISS.
From my experience, I rather prefer the CISS solution because the refilled cartridges will require frequent replacements under heavy use. Also it costs less per page using a CISS.
Personally I don't see any value to keep the printer "original" configuration given inkjet printers have gotten ridiculously cheap. The cost of a set of black/color ink cartridges already exceeds the purchase value of the printer itself.
Only downside with the CISS is the occasional failure of the cartridge head which would require replacing it with a "new" cartridge.Last edited by ghosthunter; May 29th, 2010 at 02:17 PM.
- Oct 2008
- 380
June 6th, 2010 11:50 AM #4
Both can harm your printhead. But if you use it everyday and a heavy user at that (i.e. many pages), the CISS is more cost effective. Otherwise, just stick to refillable ones.
BANNED BANNED BANNED
- Jul 2003
- 2,267
June 6th, 2010 12:07 PM #5i don't see the benefit of having the look of an original set-up. it's just a look.
June 9th, 2010 03:20 PM #6
pinag-iisipan ko din to. bihiram naman gamitin ung printer since wala naman ng nag-aaral sa amin. occassional printing na lang ng mga letters and documents. 2nd hand kasi ung printer galing sa barkada ko. ubos na ung ink and a brand new ink will cost me more or less 1.5k. ang refill per tank eh nasa 600 din. pero ung CISS nasa 2k lang ata?
ano kaya mas ok? hindi ba magbabara ung CISS kung bihira lang din gamitin?
thanks
June 9th, 2010 04:18 PM #7
June 9th, 2010 05:40 PM #8
gusto ko nga sana ung mumurahing printer na lang. but the thing is nabili ko na sa friend ko ung printer. siya ung 3 in 1 na printer. ung pwede pang photocopy since may scanner na siya. so kung refill baka mahal per page if i will use it as a photocopy machine. but then, baka naman mabilis magbara ung mga CISS.
June 9th, 2010 06:10 PM #9
I have a separate flatbed scanner if I need to photocopy a document at home. The laser printer handles it well and the rated-1500-page toner cartridge lasts a very long time. I can have the toner cartridge refilled for P800 each.
Using an inkjet printer as a photocopier tends to use a lot of ink per page.
June 9th, 2010 06:39 PM #10
I'm using 2 printers with CISS installed and on a personal note (psychological as well) I prefer seeing the ink really drain down as compared to refills - na parang orig din na di mo talaga masabi kung ubos na or yung chip lang ang nagsasabing ubos na.
In the long run oks din. I can never tell when I'll print heavily pero at least when that happens, I'm pretty confident that I know I still have plenty.
CISS is good din pala considering pwede ka magpalagay ng external waste tank. Pag refills and napuno na ang waste tank mo kailangan na magpalit, while sa CISS reset lang yung sensors and oks na.
And of course this is for Epson. Not pretty sure with Canon and HP. Just my .02
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
