actually betterplace http://www.betterplace.com/ is happening already![]()
We visited Better Place's head office in Palo Alto Nov lastyear. They presented to us the concept. Truly inspiring. Hardly a cult![]()
They already have operations running in Israel and Denmark. They got the government to opt in. So they set up a network of charging stations and commisioned Nissan to build 5,000 electric cars that betterplace is leasing out.
They are using the business model of the celfone. Build the network first then sell the units cheap. And they will only charge based on kilometers driven, much like the celfone which charges by the minute.
here are some people in our delegation. (wla ako dyan hehe)
and we also visited tesla.
they are backed up with 1,000 orders.
e-vehicles are here to stay.![]()
Romski,
As long as you use Lead-Acid batteries for your vehicles, it will have range problems and will not be accepted by the mass market. Not to mention the 15-month battery replacement that costs P160T.
Tesla and the Nissan Leaf uses lighter and higher capacity Li-Ion batteries in order to be viable.
I just want to add something.
Lead acid batteries have a shorter life if the batteries are drained deeper during each cycle. So example to illustrate:
battery drain at 80% of max capacity before recharging = 200 cycles
battery drain at 50% of max capacity before recharging = 500 cycles
battery drain at 20% of max capacity before recharging = 800 cycles
Actual capacity drain vs cycles might differ between lead acid batteries.
We have learned to accept that we are not yet meant to service the mass market. And it does not make sense to sell to PUJ's because no new franchises are being given out by the LTFRB. And existing PUJ operators are unwilling to change their units.
That is why we are servicing resorts, institutions and LGU's who want to pioneer the electric vehicle revolution for the Philippines.Right now I think what's important is to provide jobs for local workers in the auto industry.
The City of makati will soon be launching its Green route around the Central Business District. They dedicated 2 loops around Makati specifically for e-jeepneys! It's FREE!! (Not only on fares, but on emmiessions as well)Watch for it!
It's already viable marg. We have supplied to many resorts, banko central, congress, LGU's and NGO's.
And when Lithium ion becomes affordable we will also go that route. Mabuhay! May pag asa pa ang local auto industry!
False! ... The power used to charge the batteries are still generated somewhere. You can claim there are plans to generate power via bio-mass or solar, etc. But unless it is already functioning, it is just moving emissions from the tail-pipe to somewhere else. It will not be emissions-free.
The batteries themselves are toxic wastes by 1.5 years of operation. The Philippines has no facility to properly handle the proper clean/green recycling of these batteries.
Unless there is a major break through with battery technology, it will not be coming from lithium ion batteries.And when Lithium ion becomes affordable we will also go that route. Mabuhay! May pag asa pa ang local auto industry!
It's actually ....TRUEThe power used to recharge the batteries will come from the Magallanes Biodigester (hindi na plano). And a charging station has been set up at the makati Fire Station. Thus completing the clean and green loop.
If you have read up on our ejeepney project you will know that the ejeepney is just one component of the the Clean Cities Program. The other 2 components is a Biodigester which will generate energy from waste and the other is a network of charging stations.
Check it out. http://www.lucidverses.net/gripp/.
As for the batteries, Motolite now has the facility to properly recycle them. You should see their newly set up recycling plant. State of the art.![]()
Climate Friendly Cities
The Climate Friendly Cities initiative is a project that aims to contribute to climate change mitigation and promote sustainable transport and waste management initiatives.
Led by the Green Renewable Independent Power Producer, Inc., or GRIPP, in partnership with DOEN Foundation, the project aims to use energy from organic wastes from the wet markets, business establishments, and households of partner cities to power an environmentally-friendly public transport system composed of the eJeepneys.
The project consists of 3 components:
- a fleet of electric jeepneys or eJeepneys, each with a capacity of twelve (12) passengers;
- a depot that will serve as charging station; and
- a power plant consisting of a generator, an anaerobic digester or biodigester (an industrial system that promotes the decomposition of organic waste to produce biogas that can be used to power electricity generators), and a gas engine.
Biogas technologies harness biogas or methane from liquid or wet organic wastes from the livestock, food processing and beverage industries, as well as municipal solid waste and sewage treatment plants, to run a generator to produce electricity.
In the Climate Friendly Cities project, the biodigester will break down organic waste collected from municipal solid waste and sewage treatment plants, as well as the livestock, food processing and beverage industries of the partner cities. The process is as follows:
First, both the wet market and commercial food waste streams will be thoroughly cleaned of material such as metals and plastics. The waste will then be shred and mixed, and fed into digesters where their total solid content will be reduced through the introduction of an effluent such as pig manure or abattoir waste. The resulting slurry will be heated to accelerate the activity of bacteria decomposing the solids, thereby producing gas. The gas will, in turn, be fed to a gas engine that will produce electricity.
By steering clear of fossil fuels, these eJeepneys have not only revolutionized a Philippine icon, they have also provided an answer to the biggest challenge threatening our planet today: climate change.
The Climate Friendly Cities is supported by DOEN Foundation, an organization that strives towards the achievement of a liveable world in which everyone has a place. DOEN supports organizations and projects in the fields of Sustainable Development, Culture, Welfare, and Social Cohesion.
[ame="http://www.youtube.com/watch?v=8w5DaPZj7T4"]YouTube - eJeepney Inquirer net News - QCD[/ame]
[ame="http://www.youtube.com/watch?v=bqwNjPDBzvE"]YouTube - GOING GREEN IN MANILA USING THE NEW EJEEPNEY- REPORT BY CNN[/ame]
Like I said, you can show me a million green ways to power your ejeepney but as long as they remain on paper and not as an economically viable system, they don't count as "emissions free".
And by the way, the term you might be looking for might be "carbon neutral" because if you are going for burning bio-mass for power, you still have emissions.
You can only claim that your e-jeepney is "emissions-free" is IF you are powered by systems like solar, wind, etc. (Yes, there is a difference).
Loads of trouble. Why not just make more Multicabs and run them on LPG?
Or if the administration is ambitious, it could phase out PUJs altogether and replace them with tramways that Manila used to have back in its pre-war days.
Not really a viable idea anymore since the tram system will be expensive to built from scratch at this point in time.
What we need is simply a better vehicle than the jeepney as a mode of transportation for the secondary routes. A mini-bus would be ideal because it would maximize the number of people per vehicle footprint. As for the problem of unemployment of existing drivers, well, each bus wold require two people (driver and conductor) so I wouldn't think that as much of a problem.
Also designing the minibus to have two doors would make loading/unloading passengers quicker as long as people would have enough discipline to use the doors properly (one door for entry and other for exit only). Having the conductor and driver enforce such entry/exit rules would also be in their favor because they can get more people on and off the vehicle faster & more efficiently.
BTW, I hope the residents around the area where the bio-gas digester is located knows that they are now living at ground zero of a potential methane bomb.
Methane as a gas is flammable in a range of concentrations of 5% to 15% in air.
(Anyone remember the aftermath of the STARMAKER explosion?)
http://en.wikipedia.org/wiki/Methane
I love those buses roaming around in Las Vegas.
Their engines had automatic transmissions. They were a bit noisy, but visible smoke wasn't present. They had an entry door on the front and exit door at the back, two staircases, seats, spaces for wheelchairs, top-notch air-conditioning, fare collector, and most importantly, drivers who followed the rules. All of them were friendly, too. One time, a Pinoy driver gave us a ride for free.
These could work on EDSA and Makati. After all, streets in Las Vegas have roughly as much lanes as those in Makati.
