Results 1 to 10 of 16
- Sep 2007
- 8
October 4th, 2007 11:01 AM #1Hi im new here, i have a nissan sentra supersaloon 95' model a/t pag naka neutral or park okey ang exhuast but driving at speel below 30kph emits a white smoke and again pag nuetral or park wla ang smoke...do u guys know the problem? oks naman ang takbo no probs...would llike to know the problem before i bring the car to service...tnxs alot. milleage is over 100thou km
October 4th, 2007 11:14 AM #2
- Sep 2007
- 8
October 4th, 2007 01:58 PM #4
- Sep 2007
- 8
October 4th, 2007 06:25 PM #6
most probably it needs tune up nga, or check mo yung end ng exhaust pipe kung maitim or may langis,baka kumakain na kasi ng langis pero wag naman sana sakit sa ulo yun
October 5th, 2007 12:28 AM #7
sir pwede makisakay sa thread? pano kung sa morning starts may parang tubig na lumalabas sa tambucho? normal ba to sa gas vehicle? sabi ng dad ko normal to e parang di ako naniniwala
nurse on wheels
- Dec 2006
- 392
October 5th, 2007 07:25 AM #8that's normal washburn. it will burn off as the vehicle heats up. you'll notice that there's smoke too. however, if the water keeps coming out the whole day and the smoke never stops, that's a different story.
- Aug 2006
- 110
October 6th, 2007 07:59 PM #9Yes, white smoke in your exhaust is an indication of water and if it does not go away after a few minutes could mean engine trouble. If it's just moisture due to flooded roads, then the steam in the exhaust should stop. If the white smoke persists, it could mean water mixing with oil/fuel in your pistons. You may need an overhaul. Check the water in the radiator for oil or if you always need to top up the engine oil. Oil in the radiator means there might be a leak in the cylinder head. Engine oil that gets used up quickly can mean loose compression. I suggest your bring your car to a mechanic or shop so they can look at it.
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 7th, 2007 10:18 AM #10try revving the engine at a standstill and see if there is smoke. it's easier than travelling at 30kph and looking at the back
VINFAST just shows how backward our local automotive industry has been in the many decades. We...
Vinfast Philippines
