sir, newbie lang po ako but i'll try to answer your questions based on my very little experience with engines
engine performance seems to be ok, hindi ko masasabing malakas na malakas ang hatak pero ok naman
fuel mileage is quite low before i had a mechanic tune-up the car (last wednesaday) but now, after tune-up, actually spakplug lang ung pinalitan hindi pinalitan yung contact point at condenser, mukha namang nag-improve sya.
muka ngang nababawasan yung oil, nagpachange oil din kasi ako last wednesday, thinking na mawawala yung white smoke after change oil. i will be closely monitoring the engine oil from now on.
yes, muka ngang may halong oil yung usok sa tambutso
no, my engine is running smooth there are no weird sounds
i do not know how to check the valve clearance
i do not know what a valve seal looks like
normal po ba na merong konting oil, bahid lang naman, sa may bandang ilalim ng oil filter? pero wala namang patak ng oil sa ground na pinagparkingan ko.
Quote Originally Posted by 4JGtootsie View Post
Gaboy,
To solve your problem i would begin with asking questions to you.
How is your engine performance?
How is your fuel mileage?
Oil consumption?
Do you smell burning oil coming out of your tail pipe?
Any wierd noise on your engine?
have you checed your valve clearance?
Valve seal condition?
