Quote Originally Posted by gaboy View Post
mga bossing, ano ano po ba ang mga papalitan at paano ginagawa ang top overhaul?
meron ba kayong recommended na shop na magaling dito pero affordable yung price?
tnx!
hi gaboy!
depende sa kung anung makitang pyesa na damaged and out of specs:valves, valve springs, guides.you will be asked to purchase an overhauling gasket (approx.1- 1.5 k) that should include the cylinder head gasket specific for your car make.
most shops will charge you about 2.5 - 3.5 k for a gas engine overhaul (labor only)...i suggest you go to a shop that will allow you to watch the procedure. it will be a good experience (if you have time to spare).usually takes 2 - 3 hours for a top overhaul. needless to say they need to perform a compression leakage test before they open the engine, the result of which should be given to you.
