thank you very much for helping-out a newbie like me, really appreciate it sir! i really don't know much about engines/car components but very much eager to learn about it.
questions:
1. what if the white smoke does not disappear even after running the car for more than 10 minutes?
2. compression testing would determine whether the engine requires a top or general overhaul?
3. white smoke only comes out of the tailpipe and not on the cylinder head/engine, so does this mean that my engine is running ok?
4. do i still need to buy products that stops engine leaks (STP products)?
i'm located in san juan.
Quote Originally Posted by mangdencio View Post
gaboy,
white smoke (in exhaust pipe) is characteristic of starting a cold engine -the smoke disappears after a few minutes. it does not necessarily require repair..white smoke (blowby gases) coming out of the cylinder head (oil cap) may indicate oil burning in the combustion chamber. may be due to blown out gasket, broken piston rings, damaged valves, etc.this may require top or general overhaul dependent on a prior compression testing. opt for a mechanic that will explain in detail the solution to your problem.this is a way to gauge a mechanic's technical know how...some mechanics tend to take advantage of the situation specially if he sense you're willing and eager to pay the price.i suggest you seek other mechanic's opinion on your engine. the key here is compression/leak testing to confirn the need to overhaul your engine.this way, you'll know which cylinder/bore needs attention. as temporary remedy (while you prepare for engine service), i know there are products available in the market that stops engine leaks.try STP's line of products.
i'll pm you contact nos. of shops that may be of help to you asap.where are you based, btw?
