Originally Posted by
mangdencio
hi gaboy!
depende sa kung anung makitang pyesa na damaged and out of specs:valves, valve springs, guides.you will be asked to purchase an overhauling gasket (approx.1- 1.5 k) that should include the cylinder head gasket specific for your car make.
most shops will charge you about 2.5 - 3.5 k for a gas engine overhaul (labor only)...i suggest you go to a shop that will allow you to watch the procedure. it will be a good experience (if you have time to spare).usually takes 2 - 3 hours for a top overhaul. needless to say they need to perform a compression leakage test before they open the engine, the result of which should be given to you.
