Results 21 to 30 of 39
- 54,289
December 3rd, 2013 06:58 PM #21i think it's engine ping. ( pre-ignition, or "tope" in the vernacular). it comes out when the engine is challenged (during acceleration or when going up an incline).
possible causes / solution:
1. low octane fuel. switch to higher octane fuel. your manual should indicate minimum octane requirement. you might also consider filling up at another gas station for a while..
2. ignition needs to be adjusted. consult! (note: some cars automatically adjust ignition timing to fit the fuel used.)
3. dirty cylinders. have 'em cleaned, either manually (open the engine!), or using fuel additives (there's a lot of them in the market, which i personally do not believe in. heh heh..)..
4. i vaguely remember that too poor a fuel mixture (or too rich, i forget which) favors engine ping. consult!
have this look into soon, as engine ping does engine damage in the long run..
good luck.Last edited by dr. d; December 3rd, 2013 at 07:00 PM.
December 3rd, 2013 08:05 PM #22
ts, subukan mo na lang irecord ang sound at ipost mo dito...
mahirap kasi magimagine ng sound. para bang nakikinig ka ng conversation sa cartoons ng hindi mo pinapanood at iba na tumatakbo sa utak mo (if you get what i mean)...heheheh
- Nov 2002
- 32
December 3rd, 2013 09:46 PM #23Naka-experience na rin ako sa jimny ko dati ng something like a fast ticking sound na lumalakas on acceleration. Caused by a defective idle bearing, it turned out.
- Apr 2008
- 99
- Apr 2008
- 99
December 6th, 2013 01:45 PM #25
- Apr 2008
- 99
December 9th, 2013 01:09 AM #26mga sir is it possible for the cam chain, guide or tensioner to make this type of noise? went to the mechanic kanina. he said na hindi daw tope yung noise since ok naman daw takbo ng car and baka daw dun sa mga parts mentioned. safe naman daw yun and intayin ko na lang na lumakas yung noise before baklasin since matrabaho ang pagpalit ng cam chain sa honda city 04 idsi.
- Oct 2011
- 6
December 13th, 2013 05:36 PM #27
December 13th, 2013 06:49 PM #28
Had the same problem on my vios and was able to clarify with the tech and advisor. Check niyo lang kasi sabi ni SA sa akin catalyst daw un pinipurge ung carbon. Kasi ang catalyst g vios halos nasalikod ng vios.
Try to inquire din baka same location ng catalyst ng vios sa city or any other car.
Sent from my GT-I9300 using Tsikot Forums Mobile App mobile app
- Apr 2008
- 99
December 14th, 2013 12:25 AM #29
- Apr 2008
- 99
December 14th, 2013 12:28 AM #30
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
