Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
    #21
    Quote Originally Posted by tonyboy View Post
    changed oil and filter, air filter, spark plugs and caltex gold na but andun pa din yung clicking noise although very very faint. can only be heard pag walang radio and medyo tahimik ang environment sa labas. possible kaya that it has something to do with the cam chain or its parts? everytime kasi na dadalhin sa talyer ayaw lumabas yung ingay. nawawala yung ingay if either diinan or bitawan ang gas pedal.
    i think it's engine ping. ( pre-ignition, or "tope" in the vernacular). it comes out when the engine is challenged (during acceleration or when going up an incline).
    possible causes / solution:
    1. low octane fuel. switch to higher octane fuel. your manual should indicate minimum octane requirement. you might also consider filling up at another gas station for a while..
    2. ignition needs to be adjusted. consult! (note: some cars automatically adjust ignition timing to fit the fuel used.)
    3. dirty cylinders. have 'em cleaned, either manually (open the engine!), or using fuel additives (there's a lot of them in the market, which i personally do not believe in. heh heh..)..
    4. i vaguely remember that too poor a fuel mixture (or too rich, i forget which) favors engine ping. consult!
    have this look into soon, as engine ping does engine damage in the long run..
    good luck.
    May 2009
    #22
    ts, subukan mo na lang irecord ang sound at ipost mo dito...
    mahirap kasi magimagine ng sound. para bang nakikinig ka ng conversation sa cartoons ng hindi mo pinapanood at iba na tumatakbo sa utak mo (if you get what i mean)...heheheh
    #23
    Naka-experience na rin ako sa jimny ko dati ng something like a fast ticking sound na lumalakas on acceleration. Caused by a defective idle bearing, it turned out.
    Apr 2008
    #24
    good luck.
    thank you sir
    Apr 2008
    #25
    Quote Originally Posted by Aljas View Post
    thank you sir. i'll have this checked too.
    Apr 2008
    #26
    mga sir is it possible for the cam chain, guide or tensioner to make this type of noise? went to the mechanic kanina. he said na hindi daw tope yung noise since ok naman daw takbo ng car and baka daw dun sa mga parts mentioned. safe naman daw yun and intayin ko na lang na lumakas yung noise before baklasin since matrabaho ang pagpalit ng cam chain sa honda city 04 idsi.
    Oct 2011
    #27
    Kung nasa gulong or brakes, usually consistent yung sound even if he was coasting in neutral, AFAIK.
    Direct ignition na yung IDSI engines so no need to adjust timing (wala nang distributor na magagalaw). Next is to load up on the next grade fuel and check your spark plugs. Try also another gas station and fuel brand. In my case, my friend's 2011 City 1.3L was getting a bad case of tope using Petron unleaded (91 octane); she she switched to Shell Fuel Save and the tope went away. I also had the same problem with my Altis on Petron XCS, may tope na lumalabas in the last few months under certain driving conditions. I'm now using Shell Nitro+ and the tope issue went away.
    Guys, same problem sakin my clicking sound during accelerating pero pag 60kmph na wala na i'm using Petron unleaded then sabi sakin sa casa change ko raw to Shell unleaded ayun nawala sya.
    #28
    Had the same problem on my vios and was able to clarify with the tech and advisor. Check niyo lang kasi sabi ni SA sa akin catalyst daw un pinipurge ung carbon. Kasi ang catalyst g vios halos nasalikod ng vios.
    Try to inquire din baka same location ng catalyst ng vios sa city or any other car.
    Sent from my GT-I9300 using Tsikot Forums Mobile App mobile app
    Apr 2008
    #29
    Quote Originally Posted by tigerfox View Post
    sir, did you feel any difference while driving your car nung may tope? sa akin kasi ok naman in terms of gas consumption (around 10-12 km/l), acceleration and going uphill except for that clicking sound.
    Apr 2008
    #30
    Quote Originally Posted by brainmafia_310 View Post
    sir, bali normal daw yun as per the SA? yung cat converter kasi ng city ko is medyo nasa middle part but yung clicking noise is from the lower front area.
    #31
    sabi ng SA sa bicutan si Sir Ricky Busto normal daw iyun. yung tope daw po rinig na rinig at mas solido ang tunog. dun din nakalagay ung CatCon ko pero sa middle lower portion ko din naririnig kala ko nga nung una ung keychain ng susi ko ung nagloloko eh.
    Apr 2008
    #32
    thank you sir, at least i have a better idea kung ano talaga yung tope sound. ilang months na rin ako bothered dun.
    May 2011
    #33
    Light tope is normal. It's in the user manual. Kahit matic may tope at around 60kph. On my car it's more noticeable when I'm using XCS.
    I think our 1.4at fiesta totope din using XCS and unleaded 91 ron gas, maririning mo siya sa second gear going to third gear 1500-1900rpm... Anlakas ngtope sa XCS...
    Yesterday halos nag empty ako inubos ko XCS sa tank ng sasakyan then gas up UNIOIL Quntum Euro IV as experiment... Wooha after 40 km city driving humina tope, minsan wala na talaga..
    Normal lang light tope? Hindi ba harmful sa mechanism ng makina mga sir? ..
    #34
    I dunno but it seems to me Petron fuel deteriorated (save for the Blaze 100). I've been a Petron user for over ten years and now our cars seem to respond better with the additives of Shell to their fuel.
    #35
    Hmmm. Make sense. Petron user din ako since my father is an avid petron user now we bought switch na. Parang mas oks pa ang total. Now i am more on ohoenix and seaoil
    Jan 2014
    #36
    i have the same problem may clicking noise din pag nag pedal ka ng gas from gear to 2nd gear , mine is Toyota Vios 1.5GAT , only happens when acceleration or revving . pag 40-60 na yung takbo or pag stick ka ng naka apak sa gas wala na yung tunog same noise dun sa video na pinost (page 1 )
    Kahit naka aircon rinig parin pag nag rerev ako eh , at parang mas malakas siya mag noise pag naka aircon ako , until now im still experiencing the problem , im using Petron XCS for almost 2 months na dahil yun din naman ang gamit nung prev owner ng car
    May 2012
    #37
    Been a petron xcs user din until nag tope yung engine. Mukhang nag deteriorate nga.
    Nag caltex gold na lang ako, nawala yung knocking or pinging sound.
    Apr 2008
    #38
    sorry to revive this old thread pero andun pa rin yung tick/click noise. here's an audio recording:https://www.youtube.com/watch?v=Lxfx6ZnyJEo. can be hear at 4, 10 and 19 second mark.
    #39
    well... the recording isn't exactly high fidelity, and my audio system ain't nowhere near hi-fi...
    it MIGHT be engine ping..
    ask the dealer/mechanic, if it's allowed in your particular model..
    also, you might try shifting to a higher octane fuel, and see it the noise persists..
Ticking/Clicking Noise When Accelerating
