Results 1 to 10 of 25
May 30th, 2007 10:03 AM #1
how can i insulate my car from road noise? i know that it has soething to do w he tires i chose but there must be another way...help?
May 30th, 2007 12:14 PM #2
Sound deadening material in the door panels, front passenger footwells, firewall, dashboard, roof, trunk and trunk lid. Don't forget the floor boards too.
May 30th, 2007 11:40 PM #6
flashbands (available at handyman, ace hardware, and the like) are good sound deadeners...but the cheap and equally effective ones you can find in juan luna st. in binondo and comes in the form of 2 sheets of 99% industrial grade aluminum (dual sided aluminum - not aluminized!) laminated to a 3/8" fiber tech padding - the kind used in air conditioning ducts for thermal insulation (costs around +/ - 70 pesos per meter).they serve the purpose of sound deadening and radiant heat reflector and can easily be cut and glued to cover odd shapes and panels in the car. you can diy. believe me it's fun and easy. you and your car will love it! good luck!
May 30th, 2007 11:56 PM #7
Ziebart has the sound barrier, it reduces road noise significantly. But it's a bit expensive.
May 31st, 2007 09:26 AM #8
mang dencio: thank you very much! i think i will do this...kaya kasi i DIY...kaya lang di kaya babaho kapag nabasa?
falken: i think zeibart already closed its shop already
beige: thanks...ill keep that in mind
shampooking: what about mr tan's method? is this the spray on sound deadening material? or is this the same as what mang dencio suggested?
May 31st, 2007 12:51 PM #9
I forgot to mention the center hump running the length of the cabin, maingay yan kapag rear drive yung sasakyan (drivetrain and transmission kasi).
May 31st, 2007 05:23 PM #10
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
