Results 21 to 30 of 48
- Oct 2009
- 2,271
July 24th, 2016 04:16 PM #21mas ok parin sa radiator ung all copper,sa aluminum kasi lighten siya .pero para sa akin mas ok ang copper madaling i overhaul or buksan.madaling tapalan ng tingga sakali mang mabutas.at once na ipalinis mo ito pag balik parang bago na ulit.kaysa sa mga plastic top na kadalasang nakakabit sa mga bagong sasakyan ngayon,pag dating nung time na magbara na siya at kailangan buksan.pag balik minsan nagkakaroon na siya ng singaw.kasi nga hindi na factory seal ito .isa pa katagalan ng plastic nagkakaroon ng crack or pumuputok ito.
July 24th, 2016 05:38 PM #22
Also di din kailagan magpaka OC sa pag flush ng tubig sa radiator kung wala naman issue in the first place. If you read your manual most coolant lasts for 5 years or 60,000kms as long as tamang coolant ang ginamit mo. Sayang lang effort mo sa frequent palit ng tubig pero mali naman paraan mo.
- Mar 2014
- 901
July 24th, 2016 08:18 PM #23
July 24th, 2016 09:06 PM #24
Pabasa na lang sir.. Ibang "Solvent" ata yang nasa isip nyo.
Water, the Universal Solvent, USGS Water Science School
Our kidneys and water make a great pair
Our own kidneys and water's solvent properties make a great pair in keeping us alive and healthy. The kidneys are responsible for filtering out substances that enter our bodies from the foods and drinks we consume. But, the kidneys have got to get rid of these substances after they accumulate them. That is where water helps out; being such a great solvent, water washing through the kidneys dissolves these substances and sends them on the way out of our bodies.Last edited by jmpet626; July 24th, 2016 at 09:08 PM.
July 24th, 2016 09:41 PM #25
- Mar 2014
- 901
July 24th, 2016 10:59 PM #27Based on my own experienced, on two previous brand new vehicles that we had owned( both different car manufacturers). Radiator coolant from casas, never will last up to three years. If you intend to retain it for two years or so, in your radiator cooling system, expect to encounter what I had experience, a clogged in an engine cooling system. Even if the manuals says, 60k km is the replacement period. Replace or replenish your coolant every 1 or 1-1/2 year, if radiator coolant you prefer to use in your engine cooling system.
Starmobile Up+
- Mar 2014
- 901
July 24th, 2016 11:04 PM #28
July 25th, 2016 01:57 PM #29
Yes, you SHOULD replace coolant at regular intervals. Because the corrosion and scale inhibitors do not last forever.
But those inhibitors DO protect your cooling system from the effects of water, which are more pronounced if you use pure water.
We breathe corrosive gases (oxygen) every day. We drink and eat (fruit/meat/vegetable) acids that would rot your teeth if you didn't have saliva. To ask why we drink a solvent simply shows a misunderstanding of body chemistry.
Water is a universal solvent. It leaches minerals and will eventually eat its way through an iron block or an aluminum radiator. Older copper radiators took longer to corrode, but only because they used thicker tube walls... which won't fly in today's cars, which rely on the better cooling afforded by thin-walled aluminum radiators.
Even worse, pure distilled water will boil more easily, and without the protective coating of coolant, you can get cavitation bubbles with pure water that will eat through the water pump impeller or the water jackets lining the cylinder walls... in some cases, on modern diesels, this can happen in just a few hundred hours. And these effects will happen whether you change the water regularly or not. To tell someone with a newer car than you to use pure water is dangerously reckless.
Pure water isn't the answer. If you want to run nearly pure water, you need an additive such as Redline Water Wetter to forestall cavitation effects inside the engine and to prevent corrosion. Best of both worlds. You get the higher heat capacity of water, while still having the protection of coolant.
- Sep 2016
- 72
September 1st, 2016 02:29 PM #30Tanong ko lang mga sir. ung tubig ba sa labas kapag umuulan e pwedeng pumasok sa loob ng radiator? pati mga putik?
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
