Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
    #41
    Quote Originally Posted by Vodka View Post
    gate repair weekend
    i used MIG welder w/ a small portable co2 tank. if you wanna learn a welding method that'll do pretty much everything, this is it. you can build and repair gates. weld up hitch receivers and nudge bars. you can even build a motorcycle or buggy using MIG.
    TIG is precise but too slow for big metal gates
    the common stick welding is messy smoky and not suitable for thin steel.
    btw it's nice to have a 5" (125mm) grinder (3rd from the left). the common grinder here in PH is the 4" (100mm) which are little discs too small for big projects. the two cordless ones use 4.5" (115mm) discs which are even less common here
    the 5" grinder spins just as fast as a small 4" grinder so the bigger disc cuts/grinds way faster. but use branded discs only coz it could be a bit dangerous
    saw a youtube short, penetrate sa safety mask (acrylic) yun lumipad na cutter nung grider [emoji28]
    takot ako
    Sent from my Redmi Note 9 Pro using Tapatalk
    #42
    gate repair weekend
    Great boredom therapy![emoji106][emoji122]
    Jan 2008
    #43
    gate repair weekend
    Next target tool ko yan MIG welding.. yun stick.welding balbon talaga eh.. hehe
    Feb 2014
    #44
    just got a plasma cutter. here's a sample cut on a piece of steel. this thing literally cuts steel like <insert hot knife + butter cliché here>
    Jan 2008
    #45
    Nice.. clean cut
    Feb 2014
    #46
    just got a dedicated impact driver (center). the impact wrench can function as one but is way overkill and too heavy, while the right-angle impact is great in tight spaces but is too weak for certain applications
    PS in case anyone is wondering the impact driver can remove lug nuts on small cars (80 lb-ft nuts) but that's the limit. won't work on anything tighter. but still useful on smaller bolts etc
    Jan 2008
    #47
    Nice.. dumadami collection mo ha.. hehe
    When i work usually ganyan din gamit ko pang luwag ng small nut.. i also have the cordless ratchet from ryobi pero cumbersome yung battery.. mas type ko yun milwaukee m12 kasi manipis lang
    pag metal works, i use multiple grinder na.. para hindi palit palit ng blade
    Mar 2004
    #48
    Power tool whores ...
    Iyong grinder ba Malaki difference sa performance Ng 650w compared sa 900w?
    Ok din ba iyong greenfield brand?
    Feb 2014
    #50
    just got a greenfield TIG. advertised as 200A but only puts out 165A not cool, but adequate for my needs
    as for the grinder, the specs could be fake as well, but power usually isn't a limiting factor. what's more important is ergonomics
Power Tools
