Results 21 to 40 of 50
    Jan 2008
    #21
    Quote Originally Posted by Vodka View Post
    ah the brushed vs brushless debate on CORDLESS TOOLS. in most cases brushed tools are fine for the average hobbyist. they're cheaper and more reliable.
    w/ the stuff i do i only need 2 tools to be brushless: 1) drill. brushed drills spin too slow. and 2) vacuum. brushed vacs just aren't powerful enough
    but for stuff like cordless recip saws i usually overheat the blade before i get to the brushed tool's power limits. same w/ my cordless jigsaw, circular saw, oscillating, etc
    as for this brushed impact wrench it's already more than capable of loosening 100 lbs-ft lug nuts. i don't really wanna pay more for the brushless version
    mas cheaper kasi yung ozito.. tapos brushless na.. hehe.. although meron din ako nyan ryobi.. para complete lang collection.. hehehe
    Jan 2008
    #22
    Quote Originally Posted by Lew_Alcindor View Post
    That Ryobi impact wrence is enough for automobile repairs? or better get the pneumatic type?
    ryobi impact wrench is enough for automotive repairs.. na usually yung 1/2inch drive tools gamit mo.. may hex adaptor din yan pang drive ng screws..
    sa pneumatic, you need large volume compressor.. mga 50L or more.. tapos dapat at least dual hammer yung tool.. meron ako yung toptul brand.. lakas din nun..
    pero for convenience, mas ok yung cordless..
    pag tanggal nung alternator bolt, crank pulley bolt, ayos yang impact wrench, kahit hindi mo kalsohan yung pulley, tanggal..
    of course sa pag kabit, need mo ng tamang torque
    Feb 2014
    #23
    PXC 18V Brushless Impact Wrench – Skin
    cheaper? now i'm interested but it's probably weaker than the ryobi p261. seems to have smaller hammer
    Apr 2012
    #24
    recent tool purchases
    i thought mag P262 ka na bro[emoji6]
    nice vacuum and cordless washer. i think we have the same na binubutingting. i got the vacuum na, next target ko rin yang cordless washer.
    Feb 2014
    #25
    what vac did you get?
    bro the p262 is too expensive pwede na yung p261 for my 100 lb-ft lug nuts
    btw dumating na yung cordless washer. just washed the car using it. much more convenient than using my "real" pressure washer (220v). the power is actually sufficient for normal car washing, but the motor heats up a bit so i'm not sure how it'll last. for the price i'm not really complaining (ryobi ez-clean cordless washer costs like 7k)
    Jul 2013
    #26
    ayun. okay na basta kaya alternator pulley
    Apr 2012
    #27
    the same price range like yours bro. it gets the job done naman. aids well in quick drying nooks and crevices.
    mahal nga yung p262. my brother in-law in the US had the p261 for few years now and he was happy with it.
    baka cordless polisher na lang kunin ko next and keep using the pressure washer.
    Feb 2014
    #28
    dumating na rin p261. seems like i'll be retiring my pneumatic. the ryobi is lighter even w/ battery and seems to be more powerful even w/ the small battery
    Apr 2012
    #29
    does you p261 came with battery? or separate mo binili? i envy your essential power tools collection[emoji6]
    Feb 2014
    #30
    p261 for 5k, no batt included. my 2 small ryobi batts were just given to me w/ worn out cells so i just repacked them w/ genuine Molicel 18650
    dami ko pa kulang i still want the ryobi digital inflator, clip fan, portable fan, brushless cutoff, another small vacuum, SDS drill, brushless chainsaw
    Jan 2008
    #31
    malakas yan sir.. mas malakas pa sa ryobi p261.. shorter motor body since brushless motor na..
    madami na din ako ryobi batts.. pero na replace ko na lahat ng 18650 cells.. bumili ako nung spot welder and around 100pcs na 18650 batts.. kasi yung 5.0Ah eh 10pcs laman na battery.
    i have 3 units nyan ozito brushless.. yung isa comes with socket and carrying case pa.. nabili ko ng 6.5k lang.. hehe
    sa ryobi, i have all these cordless tools.. natutuwa ako sa kulay nya green eh..
    blower
    glue gun
    solder station
    heat gun
    drain auger
    multi tool
    grinder
    reciprocating saw
    impact wrench
    3/8 ratchet
    digital tire inflator with blower
    brushless driver
    brushless drill
    90 degree drill
    vacuum
    orbital sander
    trim router
    work shop led light
    hybrid shop light
    eto pa hanap ko:
    portable fan
    brushless circular saw
    nailer
    sheet cutter
    brushless grinder
    meron seller sa lazada at shopee.. tsaka may isang construction supplier sa calamba ako napuntahan, may mga ryobi sila.. tapos sa corded tools, partner yata ng ryobi ang kyocera..
    ngayon naman, nalipat ang attention ko sa bosch tools.. hehe pero mostly yung 12V tools and corded tool lang binibili ko..
    Feb 2014
    #32
    blower
    glue gun
    solder station
    heat gun
    drain auger
    multi tool
    grinder
    reciprocating saw
    impact wrench
    3/8 ratchet
    brushless driver
    brushless drill
    90 degree drill
    vacuum
    orbital sander
    trim router
    work shop led light
    hybrid shop light
    eto pa hanap ko:
    portable fan
    nailer
    sheet cutter
    brushless grinder
    wow dami ryobis. meron ka din pala spot welder, super useful. here's my re-celled pack. genuine Molicel P26A, dami fakes so i have a verification method (discharge curve matching). you can build up a battery collection for not a lot of money.
    meron din empty battery cases w/ circuit board for around P800. cheap way to get 10-cell packs, 6ah if you use 3000mah cells
    Apr 2012
    #33
    blower
    glue gun
    solder station
    heat gun
    drain auger
    multi tool
    grinder
    reciprocating saw
    impact wrench
    3/8 ratchet
    brushless driver
    brushless drill
    90 degree drill
    vacuum
    orbital sander
    trim router
    work shop led light
    hybrid shop light
    eto pa hanap ko:
    portable fan
    nailer
    sheet cutter
    brushless grinder
    that's a whole lot of power tools[emoji106] [emoji7]
    #34
    Saw this in FB. Parang mura ito even compared to shopee sellers. img_8378.jpg
    Jan 2008
    #35
    mura yan sir.. kaso maiksi yung hose nyan.. parang 3 meters lang yata.. kaya bumili pa ako ng extension..
    mas ok pang linis ng sasakyan.. sakto sa wheel well yung gun..
    kaso not self priming yan.. alam ko may ibang china brand na self priming na
    Jan 2008
    #36
    yes sir.. sayang kasi.. ang mahal ng battery eh.. although maganda naman stock batt ng ryobi.. LG yata yun eh.. kulay pula..
    kaya instead bumili ng new batt, spot welder binili ko.. tapos gamit ko 8mm strips..
    iba pa din yun factory weld eh.. mas makapal yung strips nila.. kaya dun sa 5.0ah battery, double 8mm strips ginawa ko..
    iba pala lakas pag bago yung 18650 cells.. yung blower ko lakas ng buga ng hangin eh...
    Feb 2014
    #37
    are you using 100% nickel strips? i'm using pure nickel 0.15mm thickness. mas common kasi yung nickel plated steel. an easy way to tell is if it sparks when you weld it's steel
    btw i also use pure copper for high-power applications. for power tools ok na yung pure nickel
    Feb 2014
    #38
    the rear wheel bearings on my City have been running noisy for years now the ryobi P261 had absolutely no trouble removing the spindle nut
    Jan 2008
    #39
    iba talaga pag power tools.. mabilis.. and malakas..
    actually full power yan pag reverse mode.. make sure din na impact rated yung gamit mo na socket.. yung itim.. pag yung makintab nabibiyak yan
    also don't use flower type sockets.. yung maraming points kasi manipis na yun sides at madali mabasag..
    Feb 2014
    #40
    gate repair weekend
    i used MIG welder w/ a small portable co2 tank. if you wanna learn a welding method that'll do pretty much everything, this is it. you can build and repair gates. weld up hitch receivers and nudge bars. you can even build a motorcycle or buggy using MIG.
    TIG is precise but too slow for big metal gates
    the common stick welding is messy smoky and not suitable for thin steel.
    btw it's nice to have a 5" (125mm) grinder (3rd from the left). the common grinder here in PH is the 4" (100mm) which are little discs too small for big projects. the two cordless ones use 4.5" (115mm) discs which are even less common here
    the 5" grinder spins just as fast as a small 4" grinder so the bigger disc cuts/grinds way faster. but use branded discs only coz it could be a bit dangerous
Power Tools
