Quote Originally Posted by Vodka View Post
gate repair weekend
i used MIG welder w/ a small portable co2 tank. if you wanna learn a welding method that'll do pretty much everything, this is it. you can build and repair gates. weld up hitch receivers and nudge bars. you can even build a motorcycle or buggy using MIG.
TIG is precise but too slow for big metal gates
the common stick welding is messy smoky and not suitable for thin steel.
btw it's nice to have a 5" (125mm) grinder (3rd from the left). the common grinder here in PH is the 4" (100mm) which are little discs too small for big projects. the two cordless ones use 4.5" (115mm) discs which are even less common here
the 5" grinder spins just as fast as a small 4" grinder so the bigger disc cuts/grinds way faster. but use branded discs only coz it could be a bit dangerous
Great boredom therapy![emoji106][emoji122]
