Results 21 to 30 of 217
- 54,293
December 29th, 2021 12:51 PM #21the old air-cooled beetle's jack appears to have its good points.
the way it was designed for use, one simply inserts the jack's blade into the chassis jacking point that is so very accessible under the running board, then click-jack the car up.
- 54,293
December 29th, 2021 12:57 PM #22i once bought a small alligator for the van.
when it came to use.. flat tyre... i eagerly brought it out, thinking it would be an easy job to jack the van up...
... but with the flat tyre lowering the van, masyadong mataas ang jack! i could not put it under the jacking point.
buti na lang, i still had the oem jack...
..."sino bang nalimutang grasahan 'tong scissors jack na ito..."
huff.. puff..
heh heh.Last edited by dr. d; December 29th, 2021 at 01:07 PM.
- Feb 2014
- 2,711
December 29th, 2021 01:00 PM #23
- 54,293
December 29th, 2021 01:17 PM #25
Theres a better way to deal with flat tires, inflate it back with a portable inflator and drive it to the nearest vulcanising shop and pay for the labor to switch or vulcanise the tire for you.
Invest in a heavy duty 450psi tire inflator , especially if you fun going in long road trips.Last edited by glenn_duke; December 29th, 2021 at 01:20 PM.
BANNED BANNED BANNED
- Sep 2015
- 13,917
December 29th, 2021 01:43 PM #26walangjo k_leos talaga binubusisi mo butas ng gulong.
pumunta ka servitek sa roosevelt from fisher mall mga 500meters or 1km sa left side. 150pesos patch for sedan. Yan na pinakamaayos na vulcanizing at mura magpresyo.
Sa iba 200 eh bangketa squatter ang kakapal ng mukha.
May iba maayos na store kaso feeling casa 300 to 350 singil
- 54,293
- 54,293
December 29th, 2021 02:04 PM #28
- Apr 2016
- 203
December 29th, 2021 02:25 PM #29My concern was due to reading this article specifically the paragraph:
https://www.topgear.com.ph/features/...a1219-20170528
"7. Avoid vulcanizing shops that use the sundot method. The traditional patching inside your tire lining is still the best way to seal a puncture. Some shops today offer a faster approach by inserting a seal with a sharp tool through the puncture from the outside without dismounting the tire from the rim. Though it may seem like a great convenience, it can actually damage the steel belt that keeps your tire's structure intact. I learned this the expensive way when I resorted to this method a few years ago. My tire was pretty new and two days after the job, there was a considerable bulge where the seal was. It was apparent that my tire needed a replacement. Sundot never again!"
I'd like to understand mechanically how the plug can damage the steel belt such that in 2 days, he already had bulge in the seal of his new tire.
This is part of a tire.
Now imagine you push a screw driver into the hole, would the belt and ply simply have clean holes or would the section of the belt and ply be pushed outward such that there is slight separation between the tread and belt/ply? If you have spare tire that you don't need anymore. Can you try pushing screw driver in a hole to see what would happen?
This was my tire with a hole punctured by a screw.
After the technician pulled out the screw, he inserted a screw driver all the way in (making bigger hole so the plug can fit).
Then put the plug.
I'd like to know what kind of pushing can really damage the steel belt as the above article detailed. Want to analyze why it happened to his belt such that after 2 days, meron na bulge. I'd still use the tire for the next 10 years (it's also somewhat new, look at the tread) because I seldom use the cars. Hence I need to know the details of how damage to steel belt can really occur from plugging repair. Salamat.
- Sep 2015
- 13,917
December 29th, 2021 03:29 PM #30pangit talaga tusok. Dati once natry ko yan curiosity. Yung gulong kasi dahan-dahan nawalan hangin so tolerable gamitin kahit weeks iniinflate ko na lang. Nung naisipan ko paayos eh tinary ko tusok ayun after 2days superflat gulong ko hahaha!!! Mas ok pa hindi ko na pinagalaw.
so puro patch na ako.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
