Results 11 to 15 of 15
- Sep 2007
- 215
September 28th, 2007 07:04 PM #11spark plus could be one of the reasons ... pero marami rin nang gagaling and vibrating ...
try mo tingnan kung kailangan linisin yung throttle body ng car mo usually madumi or you can check you air cleaner ...
high tension wire can also be one problem ... but usually pag brittle or my open wires usually and signs na sira siya ... one way to test if your gutsy enough tangalin mo yung high tension wire slightly lang and you can hear sparking ... if you can hear it okay pa yan .....
maraming reasons and depende rin sa cars please give more details
Banawe Auto Supply
regy
September 28th, 2007 10:06 PM #12
bumabagsak lang idling niya actually pag nag-brabrake ako. ek '96 vti nga pala car ko. pero i think due na din iyong change sparkplugs ko
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 30th, 2007 02:20 PM #13idling problems on hondas are solved through the intake manifold cleaning and iacv cleaning.
October 5th, 2007 12:31 PM #14
^i already cleaned it myself earlier this year. could it be possible that it got dirty again in such a short span of time
- Nov 2003
- 3,849
October 7th, 2007 10:25 AM #15probvably not but it can't hurt to clean it again. if ayaw maayos then normally it requires replacing the sensor na.
high idle RPM at engine start
